SolaraGuy.com • View topic - Boosten @ 5.5psi now!!!
Postby shocar4 » Mon Jul 17, 2006 6:22 am
yep i got my 2.9 pulley in the mail and had it installed in about 25 minutes! wow i can sure tell a difference....any idea on how much hp that would add compared to the stock 3.2 pulley?
shocar4
Postby SC V6 » Mon Jul 17, 2006 7:20 am
better tune that one... its great for more power, but more power = more likely to damage a piston
SC V6
Postby shocar4 » Mon Jul 17, 2006 7:57 am
see i asked this before...do i have to do anything with my split second system now?
shocar4
Postby SC V6 » Mon Jul 17, 2006 8:08 am
get it tuned in properly... I'd just be careful, I've heard of many people blowing their motors on here. You have headers?
SC V6
Postby Wang2k » Mon Jul 17, 2006 8:10 am
you just need to add more fuel...do u have a wideband?
Wang2k
Postby shocar4 » Mon Jul 17, 2006 8:16 am
Wang2k wrote:you just need to add more fuel...do u have a wideband?
sorry man i am new to this, not sure what a wide band is???? what exactly do i need to do? sorry for my ignorance!
shocar4
Postby shocar4 » Mon Jul 17, 2006 8:17 am
SC V6 wrote:get it tuned in properly... I'd just be careful, I've heard of many people blowing their motors on here. You have headers?
with all my supporting mods, does 1.5 psi really create that much of a problem?
shocar4
Postby SC V6 » Mon Jul 17, 2006 8:17 am
wideband is refering to wideband o2 which is needed for tuning the whole fuel map. hit up a dyno and get it tuned in
SC V6
Postby shocar4 » Mon Jul 17, 2006 8:21 am
SC V6 wrote:wideband is refering to wideband o2 which is needed for tuning the whole fuel map. hit up a dyno and get it tuned in
isn't this what the split second fuel calibration deals with?
shocar4
Postby SC V6 » Mon Jul 17, 2006 8:29 am
yes... you would be surprised with our motors how much an extra 1.5psi can do
SC V6
Postby Wang2k » Mon Jul 17, 2006 8:34 am
A wideband o2 sensor goes in your exhaust seperate of the other oxygen sensors. It hooks up to a digital display inside that shows you your cars air/fuel ratio. You then use that info to add fuel at lean rpm/load places. With your SS FTC it controls part throttle as well as WOT so u have to tune the whole map based on different circumstances
Wang2k
Postby shocar4 » Mon Jul 17, 2006 8:38 am
Wang2k wrote:A wideband o2 sensor goes in your exhaust seperate of the other oxygen sensors. It hooks up to a digital display inside that shows you your cars air/fuel ratio. You then use that info to add fuel at lean rpm/load places. With your SS FTC it controls part throttle as well as WOT so u have to tune the whole map based on different circumstances
you are really helpful! so can i do this with my ss ftc? or do i have to take it to a dyno shop?
shocar4
Postby SC V6 » Mon Jul 17, 2006 8:42 am
well.. under closed loop (WOT) your S.S. will take over completly, under open loop (anything lower than 90-100% throttle) your ECU will change things, you S.S. will still have input to the ECU, but the ECU will adjust things at will.
You can get a wideband o2 setup which allows for a gauge that can be hooked up inside the car to see what your running for air/fuel ratio. To get tuned in, the easiest is to go to a dyno. Street tuning is more complicated.
SC V6
Postby shocar4 » Mon Jul 17, 2006 8:45 am
SC V6 wrote:well.. under closed loop (WOT) your S.S. will take over completly, under open loop (anything lower than 90-100% throttle) your ECU will change things, you S.S. will still have input to the ECU, but the ECU will adjust things at will.
thanks man you guys are great! so do i need to do anything with my ssftc? can i hook my ssftc up and see what my f/a ratio is or if i am running lean?
shocar4
Postby SC V6 » Mon Jul 17, 2006 8:50 am
your split second won't show if you are running lean or not.. you have to go to a dyno or somewhere with a wideband o2 to see what you are running, then dial it into the S.S.
SC V6
Return to Forced Induction
Users browsing this forum: No registered users and 106 guests
