SolaraGuy.com • View topic - just clearing things up
Postby woa_its_j3ff » Thu Jul 20, 2006 5:30 pm
I'm not saying I don't know the difference but I may be a little rusty on the facts of the three..
what is the difference between, supercharged, turbocharged, and procharged?
Clarification
Postby JMSinMaryland » Thu Jul 20, 2006 5:40 pm
Use the internet to your advantage, plenty of info out there.
1. Supercharged is forcing new air into the engine to create more power, usually belt driven such as TRD
2. Turbocharged is using exhaust gases to spin a rotor to force more air into the engine, referred to as centrifugal
3.Procharged?
JMSinMaryland
Re: Clarification
Postby woa_its_j3ff » Thu Jul 20, 2006 5:42 pm
JMSinMaryland wrote:Use the internet to your advantage, plenty of info out there.
3.Procharged?
yeah ive heard a lot of talk bout "procharged mustangs, or procharged vettes" maybe I just got confused with the bunch..
i even tried googling it, but it didnt really clear up much of anything..
Suggestion
Postby JMSinMaryland » Thu Jul 20, 2006 5:46 pm
http://www.howstuffworks.com/
Try harder :roll:
ps I believe Procharger might be the name of a company that produces superchargers?
pps. I just went to the site above and it all seems to be there, here's just a quick paste
Let's start with the similarities. Both turbochargers and superchargers are called forced induction systems. They compress the air flowing into the engine (see How Car Engines Work for a description of airflow in a normal engine). The advantage of compressing the air is that it lets the engine stuff more air into a cylinder. More air means that more fuel can be stuffed in, too, so you get more power from each explosion in each cylinder. A turbo/supercharged engine produces more power overall than the same engine without the charging.
The typical boost provided by either a turbocharger or a supercharger is 6 to 8 pounds per square inch (psi). Since normal atmospheric pressure is 14.7 psi at sea level, you can see that you are getting about 50-percent more air into the engine. Therefore, you would expect to get 50-percent more power. It's not perfectly efficient, though, so you might get a 30-percent to 40-percent improvement instead.
The key difference between a turbocharger and a supercharger is its power supply. Something has to supply the power to run the air compressor. In a supercharger, there is a belt that connects directly to the engine. It gets its power the same way that the water pump or alternator does. A turbocharger, on the other hand, gets its power from the exhaust stream. The exhaust runs through a turbine, which in turn spins the compressor (see How Gas Turbine Engines Work for details).
There are tradeoffs in both systems. In theory, a turbocharger is more efficient because it is using the "wasted" energy in the exhaust stream for its power source. On the other hand, a turbocharger causes some amount of back pressure in the exhaust system and tends to provide less boost until the engine is running at higher RPMs. Superchargers are easier to install but tend to be more expensive.
JMSinMaryland
Postby woa_its_j3ff » Thu Jul 20, 2006 5:54 pm
^ thanks man. that actually helped me out a lot. forget google :)
Postby calreef18 » Thu Jul 20, 2006 6:39 pm
And Procharger is a s/c company.
calreef18
Postby DatSRBoi » Thu Jul 20, 2006 7:15 pm
Procharge works like a turbo but use belt power like the supercharger.
Return to Forced Induction
Users browsing this forum: No registered users and 64 guests
