SolaraGuy.com • View topic - Denso Iridium IK22's?
Postby scdsolara619 » Wed Jul 26, 2006 10:55 pm
Just wondering how long should you run the plugs before changing again. I was told 30K miles, but seems a little too soon, for me at least. How long do you guys run with those?
Thanks.
02 SE V6 (S/C) AT
scdsolara619
Postby Sleeper » Thu Jul 27, 2006 1:15 am
Are the IK22 a good set up to use on our cars?
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby SC V6 » Thu Jul 27, 2006 6:04 am
for S/C applications only
SC V6
Postby JavaJoe_2 » Fri Jul 28, 2006 9:28 pm
Sleeper wrote:Are the IK22 a good set up to use on our cars?
I have a set of new IK20's FS $45. shipped! :o
JavaJoe_2
Postby StockSolara » Fri Jul 28, 2006 11:46 pm
Iridium are said to last 100,000 miles
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Turbosolara » Sat Jul 29, 2006 1:06 am
depend on how well is your computer tuned. mine last only 10000 miles because it runs under the harsh condition of rich and lean
Postby scdsolara619 » Sat Jul 29, 2006 3:27 pm
I found this on the DENSO website under FAQ:
Q. How long will Iridium Last?
A. Iridium use represents the most significant technological advance in automotive spark plug manufacturing, since platinum was introduced in the early eighties. As vehicle manufacturers produce increasingly complex and efficient automobiles, there is a greater need for long-life plugs that can tolerate leaner fuel mixtures and improved combustion processes. DENSO has responded to this need by developing its Iridium alloy, originally for OE applications. For example, many newer Lexus’ and Toyota models carry an ultra long-life Iridium plug variation (.7mm with platinum tipped ground) that is capable of up to 120,000 miles of service. DENSO Iridium Power plugs, with their .4mm center electrode, have been developed for performance applications. Because gradual wear will “round-off” firing points over time, the concentrated firing power and voltage requirement benefits will be reduced. For this reason, DENSO advises replacement after 30,000 miles.
I guess it all depends on the tip size, therefore the IK22 should be replaced after 30,000 miles.
02 SE V6 (S/C) AT
scdsolara619
Postby siennasc98 » Sat Jul 29, 2006 9:44 pm
scdsolara619 wrote:I found this on the DENSO website under FAQ:
The Iridium (Denso P/N SK20R11) .7mm sparkplug with platinum tipped ground from Toyota/Lexus is the one I'm using.
The Toyota P/N is 90919-01210.
The currently installed (6) plugs on my 98 Sienna are in service for about 47k miles now and they are still excellent condition.
siennasc98
Postby Sleeper » Sat Jul 29, 2006 10:12 pm
so what would be better? IK20 or IK22? My friend had a supercharged EG on a K Series motor using IK22 and 2 of the electrodes cracked off completely. I've never seen that before.
SLEEPER...
Sleeper
Return to Forced Induction
