SolaraGuy.com • View topic - Uh SC Belt help?
Uh SC Belt help?
Uh SC Belt help?
Postby DatSRBoi » Sun Jul 30, 2006 9:12 am
Haha guess everyones belt are being replace...But I couldnt find a dayco belt anywhere. I went to Orilles (how ever you spell it) and got a generic one. Only thing is the belt is 6pk2230.... I went ahead and brought it. Is this safe for 4 psi and 5.5? It was either that or a 6pk2245 which i know is too long.
The belt is Gaters Micro-V K060878 ( 6PK2230) I was told this fits.
Postby DatSRBoi » Sun Jul 30, 2006 7:09 pm
Aww no help? Ill check again in an hour. Putting the stuff in tonight to get ready for the dyno tune. Lets see if I can pass the 243whp mark.
Dayco
Postby PDX SuperSolara » Wed Aug 02, 2006 1:20 pm
I use and recommend a Dayco Polycog belt. If it doesn't slip, any belt should be fine. I am running a 7 psi pulley so I don't remember what size I used with bigger pulleys. If you really want a Dayco, tell me what size you need and I'll tell you what it costs for me to send ya one.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby Astro » Wed Aug 02, 2006 7:39 pm
I got mine at Kragen online. The 1997 FORD RANGER V6 3.0 Liter FI uses this belt stock (6PK2235/5060880). Probably costs me more here, but at least it's the right one.
http://www.partsamerica.com/ProductList.aspx?MfrCode=DAY&PartType=1063&PTSet=A&SearchFor=Serpentine+Belts
Postby Ian » Thu Aug 03, 2006 8:17 pm
There is a good thread on this site somewhere with that information. I relied on it when I got my Dayco for my 6lb pulley. The guy provided the sizes and explanation of the item numbers. The thread was done this year.
Ian
Postby siennasc98 » Thu Aug 03, 2006 9:05 pm
TRD Supercharger belt vs. Dayco Poly-Cog belt;
Solara/Camry/Avalon without Dynamic Tensioner
TRD P/N 00602-17620-330
Metric P/N 6PK2225
Poly-Cog 5060875
Solara/Camry/Avalon with Dynamic Tensioner
TRD P/N 00602-17620-332
Metric P/N 6PK2250
Poly-Cog 5060885
Sienna with Dynamic Tensioner
TRD P/N 00646-17620-331
Metric P/N 6PK2285
Poly-Cog 5060900
For my Sienna with 2.9" (5.5 psi) pulley, I'm using this smaller Dayco belt (no slipping or rattling);
Metric P/N 6PK2275
Poly-Cog 5060895
To get the belt lenght, use the Metric P/N, the last 4 digits is the length of the belt in millimeter;
2225 mm /25.4 mm/inch = 87.5 inches
2250 mm /25.4 mm/inch = 88.5 inches
2285 mm /25.4 mm/inch = 89.96 or 90.0 inches
2275 mm /25/4 mm/inch = 89.7 inches
Reference:
http://www.mvreader.com/multiview/dayco ... Search.y=0
siennasc98
Postby Ian » Sat Aug 05, 2006 6:13 am
That's the exact info I was talking about. That's what I used. I have the 6lb pulley so I think I used Poly-Cog 5060880
P.S. The Dayco is a good belt.
Ian
Return to Forced Induction
Users browsing this forum: No registered users and 64 guests
