SolaraGuy.com • View topic - IK22 vs. IK20
IK22 vs. IK20
IK22 vs. IK20
Postby HaliGuy69 » Thu Aug 17, 2006 6:25 am
I know one of these (IK20?) are normally just used for S/C application but is there any harm running them on a non-S/C vehicle? Im trying to find a charger but the plugs are due to be changed and I'd rather not have to change them again when I find a charger. Thanks for your help guys. And if anyone has a S/C for an Automatic for sale PM me.
HaliGuy69
Postby Ian » Thu Aug 17, 2006 7:01 am
IK-22's are for supercharged, the IK-20's are for stock. Get the right one.
Ian
Postby StockSolara » Fri Aug 18, 2006 12:14 am
The IK22 are one step colder for the S/C. . . I wouldn't suggest using the one step colder for a N/A application
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Turbosolara » Fri Aug 18, 2006 12:14 am
it will be less efficient = no good
Postby Sleeper » Tue Sep 05, 2006 12:25 pm
Is there a big difference between the IK20 and 22's? Im charged but I was about to go buy the IK20s to be safe, do I run any risk using the IK22's??? Thanx
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby Jon11582 » Tue Sep 05, 2006 12:30 pm
Sleeper wrote:Is there a big difference between the IK20 and 22's? Im charged but I was about to go buy the IK20s to be safe, do I run any risk using the IK22's??? Thanx
You run a risk by running the IK20s. Run the IK22s if your S/Ced.
If you run plugs too hot, it can cause pre-detonation and knocking.
2000 Black Solara SE
Jon11582
Postby Turbosolara » Tue Sep 05, 2006 12:37 pm
if you have trd superchager, you will be fine with ik22. in fact, you might feel improvement with ik22
Postby Sleeper » Tue Sep 05, 2006 2:08 pm
I was reading on the denso website, and it said that the colder spark plugs aren't recommended for daily stop and go traffic. And in LA thats all there is. They are recommended for racing whereas the engine heats up to higher temps where these spark plugs help dissipate the heat more efficiently
SLEEPER...
Sleeper
Postby DatSRBoi » Tue Sep 05, 2006 4:17 pm
Just to be an A$$Hole..... :)
If you flippin blowing money on a supercharger blow money on the god dam right plugs fuckers. If your not or will be blowing money on a supercharger then the other plug until you do. Whats more important? installing the right plugs and getting whats worth out of your toyota or being a screwed up carless mofo and screwing your car overbecause you tried to "save" time.. Its call R&D. if its said to be bad, its so. Nuff said :)
For sleeper.. I think its never safe to run boost daily anyways even if its facotry. Anything will kill our engines sooner or later because heats everywhere. I also think if you change your plugs more often that reduces that issue?. Thats why you and I have fun raping them V8s while it lasts hahah.
Postby QuickSEV6 » Tue Sep 05, 2006 4:32 pm
DatSRBoi wrote:Just to be an A$$Hole..... :)
If you dilly-dallying blowing money on a supercharger blow money on the god dam right plugs fuckers. If your not or will be blowing money on a supercharger then the other plug until you do. Whats more important? installing the right plugs and getting whats worth out of your toyota or being a fluffied up carless mofo and screwing your car overbecause you tried to "save" time.. Its call R&D. if its said to be bad, its so. Nuff said :)
What?
Postby camry_101 » Tue Sep 05, 2006 4:58 pm
ik20s are safe
2007 Ninja 500R stock
camry_101
Postby Sleeper » Tue Sep 05, 2006 5:07 pm
So is it safe to assume the IK20 are direct replacements and 22's are for better performance?
SLEEPER...
Sleeper
Return to Forced Induction
Users browsing this forum: No registered users and 110 guests
