SolaraGuy.com • View topic - Compendium of Boosted Solara Info - A Case by Case Study
Postby DatSRBoi » Sun Aug 27, 2006 10:25 pm
Everyone, please follow the below format and as time passes make changes to your original post ONLY. DO NOT chat in this thread. Your posts will be deleted. Mod can you make this a sticky and delete and chat? I see other forums doing this and I think it is a very useful tool rather having to search each individuals its all here. Everyones whose boosted please add to it. NO CHAT please.
Induction Type: Supercharger
Type of Motor: 1Mz-Fe
Transmission: 5Speed
Date Boosted: November 2005
Milage on Boost Date: 13,000mi-ish
Current Milage: 94,000-ish
Daily Driver, Seasonal, Weekend Car or Trailer Queen: Daily Beater
Boost Kit (or major component brands if custom): TRD Supercharger
PSI: First 8 months - 4psi, Since then 5.5psi
Management System: SAFC2,
Oil Used Since Boost: Mobil 1 10w30
Oil Change Frequency: 3,500mi
Most Recent Dyno Numbers and PSI: 260WHP / 237.WTQ @ 5.5psi
Reason You Thought Your Setup Was The Best Choice For Your Needs
I wanted Power and I wanted it to be dependable. I feel I got both with my setup. Also I feel safe driving it long distance with less mantainance and its easy on my money. On the road The car performs well and doesnt give me any issue ever since the setup was completed. I mean, why have allot of power on a luxury car if its always breaking down or always draining your wallet?
What Kind Of Person Do You Think Your Setup Is Ideally Suited For?:
I Think this setup are for people who wants to have a bigger push then just stock supercharged yet easy on their wallet. Who would want to complain with 300 hp at their comand?
Please List All Parts You Have Broken/Replaced That You Would Blame
On Being Boosted and What You Replaced Them With:
Knock Sensor - Replaced with GM
Tires thicker and wider
Spark Plugs with copper
Please List Any Service or CEL Codes You Have Had To Deal With Due To Boost:
Lots of Brake replacements
Upgraded thermostat (But car still feels hot)
Knock sensor failure Code
Gas Milage: 20-25mpg on 93 octane (90% highway) and 12-18mpg (90% city)
Other Info You'd Like To Share:
I feel very safe on 5.5 PSI rather the 6 PSI pulley. Im able to run the car in long distances and still see it keeping up on the demands and not getting tired. I do notice the car gets hot still.
List of ENGINE MODS ONLY:
TRD Supercharger 5.5 PSI
GM Upgraded SC Coupler
Apexi SAFC2
TRD EBC
TRD THermostat
Jim fuel line
Upgraded Fuel Filter (Forgot brand)
190Walbro
Supra 305 Injectors
Injen Intake
GM Knock Sensor
Shorter SC grip belt
GM S/C Coupler kit
Cold Air Extension
Tanabe G medallion Full Cat-Back Exhaust
Custom STRAIGHT Y pipe 3 inch
Custom Drop pipe 3 inch(Between the Y pipe and headers)
Straight Test Pipe 3inch
O2 bypass
HKS Groundwires
NGK Copper Performance Spark Plugs
Dat[/b][/b]
Castro's 97 Camry S/C 4psi
Postby CASTRO » Mon Aug 28, 2006 1:40 am
Transmission: 4Speed Auto
Date Boosted: September 2005
Milage on Boost Date: 120,000mi-ish
Current Milage: 167,000-ish
Daily Driver, Seasonal, Weekend Car or Trailer Queen: Daily driver/ Circuit Track car (not drag)
PSI: First 8 months - 4psi, before 5.5psi
Management System: stock TRD boost piggyback,
Oil Used Since Boost: Full synthetic Mobil 1 5w20
Oil Change Frequency: 3,000mi
Most Recent Dyno Numbers and PSI: 210WHP / 190.WTQ @ 4psi
The car has always been looked down on. I brought it to the track as a joke and for fun, but quickly learned that it can keep up with many others there including fully moded 240's and Toyota Corollas with swapped engines. I say keep up because heavy weight and an auto tranny kept me from passing. I needed more power on the track. I am a perfectionist, I love maxing out anything I own including cars. The supercharger and all the other bolt-ons just makes me feel that I've done as much as possible and it allows closure to move on to another car. lol
The person who wants a dependable car that can take a lot of unsuspecting "street-racers" (gives them the wow-factor). Track junkies that love to surprise people with a strange fast car... only to ask "Is that a Camry on the track?"
Knock Sensor - Replaced with GM/spliced to read from 1 sensor
13.1inch Supra TT brakes
Spark Plugs with iridium
Lots of Tire replacements
Upgraded thermostat to TRD 160*
Upgraded radiator cap TRD 1.3bar
EGR insufficient flow code
P0171 lean mixture code
Gas Milage: Full tank ~350-370miles freeway/city mixed driving
My car had TCS and would always cut power since at the time I had stock tires/system on. I blew a knock sensor from going WOT and the s/c was boosting while the TCS system was fighting it. Permanently disabled TCS, replaced/modded knock sensor + wires and all is good. Tried 5.5psi and always had the lean code. Swaped back to 4psi next day in fear of damange. 4psi track tested for 3 6hr Buttonwillow track sessions under HARD driving. No wear and tear issues other than tires and suspension. Tranny cooler highly recomended.
TRD Supercharger 4 PSI
TRD EBC
TRD Thermostat
TRD 1.3bar Radiator car
URD ESC1
DatsYPipe w/Cat-delete
Jim's fuel line
Injen Intake + UPFD CAI
GM Knock Sensor
Greddy Evo1 w/removed 2 resonators -- Full Cat-Back Exhaust
Added 4ga wire from alternator to + battery terminal
Upgraded Groundwires (4ga)
NGK Iridium Spark plugs
B&M tranny cooler
CASTRO
Re: Compendium of Boosted Solara Info - A Case by Case Study
Postby QuickSEV6 » Mon Aug 28, 2006 2:52 am
Type of Motor: 1MZ-FE
Transmission: 5 Speed Manual
Date Boosted: April 2002
Milage on Boost Date: 8000
Current Milage: 73000
Daily Driver, Seasonal, Weekend Car or Trailer Queen: Daily Driver
PSI: First 8 months - 4psi, Since then 7psi
Management System: Apex'i S-AFC II
Oil Used Since Boost: Redline 5w-20
Oil Change Frequency: Yearly
Most Recent Dyno Numbers and PSI: 286WHP (Since dyno, knock sensor blew, greatly reducing power)
Its a never ending project. I want the best car on the street. Most power, best handling, great audio and smoothest ride. Still a work in progress - more to come.
The only person that matters. ME! I don't care what anybody else thinks. Its my car and it demonstrates my personality. I special ordered it from the dealer. This is MY car and nobody elses.
Knock Sensor - haven't replaced yet. This is due to fuel system. New fuel system coming.
Knock sensor. See above.
Gas Milage: not entirely sure.
This is my baby - soon to be a supersolara.
TRD Supercharger 7 PSI
Apex'i S-AFC II
Denso Iridium Spark Plugs IK-22
Custom exhaust. 3" plumbing, Hi-flo cat and Magnaflow muffler
K&N air filter
Plasmabooster
Redline Water Wetter
Brian
Postby Fletch » Mon Aug 28, 2006 5:39 am
Induction Type: S/C
Transmission: MT
Date Boosted: Summer '04
Milage on Boost Date: 105k
Current Milage: 130k RIP
Boost Kit (or major component brands if custom): TRD/Kazuma
PSI: 4 psi, a few months later 5.5psi
Management System: none
Oil Used Since Boost: Straight 30
Oil Change Frequency: 3k
Most Recent Dyno Numbers and PSI: none
Never can have enough power, sleeper
Anybody considering FWD car with good styling, but not look at me looks, above average performance, reliability
Knock Sensor - never replaced, rewired
Knock sensor
Gas Milage: 18 - 21 City / 26 Highway
Other Info You'd Like To Share: Hit tree and rolled = totaled
2.9" Pulley
Jim's Fuel Upgrade (after blown knock sensor)
Greddy Cat Back
Custom Cat Delete 2.5" Y-pipe
Lightweight Flywheel
Torque Rod
K&N Drop In Filter
2006 Legacy GT spec.B
Fletch
Red Knight
Postby trd4life » Fri Dec 15, 2006 4:29 pm
Induction Type: TRD Supercharger
Transmission: Auto
Date Boosted: unknown
Milage on Boost Date: unknown
Current Milage: 54,000
PSI: 9.5 psi
Oil Used Since Boost: Amsoil 10w-30
Most Recent Dyno Numbers and PSI: 320WHP / 316WTQ @ 9.5psi w/ 75shot
I wanted the Red Knight cause it looks sick and screams
Me
Headgaskets
Plugs
02 sensor
Bank 1 Rich Condition
Gas Milage: 18-20mpg on 93 octane (90% highway) and 10-12mpg (90% city) This car gets the worst gas mileage ever
I love the car but the auto trannys are weak and blow up pretty easily.
Fully Built 3.1L 1mz-fe engine using oversized Forged Arias Pistons 9:1 compression, Eagle rods, Polished crankshaft, ARP head and main studs, MLS headgaskets, Ported polished heads w/ 3 angle valve job
Ported TRD Supercharger 9.5psi URD pulley
ported Lower intake
URD Crankshaft pulley
Airaid TB spacer
Apexi SAFC2
Greddy Emanage Ultimate (going in soon)
TRD Thermostat
Jim fuel line
255lph Walbro Fuel pump
RC 370cc injectors
Custom 3.5" Intake tube
Supra TT MAF
GM Knock Sensors
Shorter gatorback s/c belt
Under Pressure Cold Air Extension
JP Performance Headers
JP 3" Catback Exhaust and 3" Test Pipe
O2 bypass
Ignition Solutions Plasma Booster
Perma Cool Oil Cooler
Magnecore Wires
NX Wet kit w/ purge, bottle warmer, FP safety switch
Gabe
Postby Akfahad » Fri Dec 15, 2006 10:28 pm
Date Boosted: July 2004
Milage on Boost Date: 64,000ish
Current Milage: 103,000
PSI: First year - 4psi...since ~July 2005, 6psi
Management System: AFC Neo
Oil Change Frequency: 3-4,000mi.
Most Recent Dyno Numbers and PSI: 286WHP / 278WTQ @ 6psi
-Needed a daily driver and wanted to mod at the same time. Origionally was only going to drop it and put rims on it, but I caught the disease and haven't stopped since I bought the thing back in 2001 (winter).
-Anybody who wants the look of a nice clean semi-luxury car and a little power to boot.
-Blown knock sensor after a day at the track. I didn't let the engine cool down enough between runs. Didn't replace knock sensor, re-wired the ECU to the good sensor.
-Uneven idle at times, had to replace TPS/IAC valve (don't know if it's due to boost or just needed to be replaced).
-Will get "system too rich" code from time to time (PO134 I think), but usually goes away within a couple of miles.
Gas Milage: 20-25mpg on 93 octane (90% highway) and 12-18mpg (90% city) <<<about right for me too, never did the math but I can get ~350 miles on a tank of gas, city driving.
-This car has been nothing but good to me and I hope it keeps on truckin'. I intend to drive her until she dies. I feel comfortable with 6lbs. of boost, one: because of a long discussion I had with JoeB, and two: I tend to baby it when I drive, rarely do I push her (changes in mood and track days will change that).
TRD Supercharger 6 PSI
Apexi AFC Neo
JP Performance headers & Y-pipe
Jim's Fuel Rail Upgrade
Upgraded Fuel Filter (from Jim again)
Walbro 190LPH fuel pump
318cc injectors
Injen Intake with UPFD extension
K&N XStream filter
Denso Iridium spark plugs IK22
NRG Innovations Oil Catch Can
Supra TT MAF sensor
Meth-Injection Kit: Stage 2 MAF Boost Cooler (Snow Performance)
Optima Yellow Top Battery (not really a mod, but...)
Postby scdsolara619 » Wed Mar 07, 2007 3:33 pm
Transmission: Auto
Date Boosted: August 2002
Milage on Boost Date: 5,200 mi
Current Milage: 77,000 mi
PSI: 4 psi all along
Management System: SAFC (not yet tuned),
Oil Used Since Boost: Valvoline 5w30, Mobil 1 5w30
Oil Change Frequency: 2,500 - 3,000 mi
Most Recent Dyno Numbers and PSI: 192WHP / 184WTQ @ 4.0psi
I wanted Power and I wanted it to be dependable. I feel I got both with my setup. Also I feel safe driving it long distance with less mantainance and its easy on my money. On the road The car performs well and doesnt give me any issue ever since the setup was completed. I mean, why have allot of power on a luxury car if its always breaking down or always draining your wallet? (exactly my thought)
Anyone that wants it and that can afford it. Nothing wrong w/grandma w/boost.
Dynamic tensioner (5 times)
NONE
Gas Milage: 22-26mpg on 91 octane (90% highway) and 17-19mpg (90% city)
I left mine @ 4 psi because I still have an extended service plan until Mar '08 or 100k miles - also i know I could get more power out of it, but I'm happy with it. Hasn't given me any problems, so why mess with it?
Apexi SAFC
TRD EBC
Denso Iridium IK22 spark plugs
Magnecor 8.5mm wires
02 SE V6 (S/C) AT
scdsolara619
Postby mzfe5speed » Sun Mar 18, 2007 6:20 pm
Date Boosted: 3/17/07 thru 8/5/07
Milage on Boost Date: 133,700-141,500
Current Milage: 142,000-ish
PSI: stock pulley, 4psi
Management System: None
Oil Used Since Boost: Mobil 1 5w30
Most Recent Dyno Numbers and PSI: None
I wanted Power and to be dependable. I feel I got both with my setup. Also I feel safe driving it long distance with less mantainance.
Me!! :) And anybody else who wants a boosted family sedan!
Plug wires with Magnecor
Spark Plugs with Denso Iridium
One weak vacuum hose that kept popping off, replaced with heavy duty hose.
Nothing that hasnt come up before.
Gas Milage: 22.5-24 city, 28-30 highway. usually around 23.5 with normal week of driving, mostly city w/ a little highway.
Having a Boosted Camry is Awesome!!! Well, it WAS Awesome!!!
TRD Supercharger
Injen Intake w/ Cold Air Extension
Greddy Full Cat-Back Exhaust
Custom Y-pipe 2.5 inch, Cat-Deleted
HyperGround System
Magnecor Plug Wires
Go Camry Go!!!
Was Officially BOOSTED!!
(And Loved It!)
http://www.cardomain.com/ride/2488906
mzfe5speed
Postby Gregtrd » Mon Nov 19, 2007 9:10 pm
Type of Motor: swaped 5sfe to 1Mz-Fe
Transmission: swaped auto to 5Speed
Date Boosted: march 2006
Milage on Boost Date: 86,000mi-ish
Current Milage: 98,000-ish
Daily Driver,
[b]Boost Kit (or major component brands if custom):
TRD Supercharger
PSI: 5.5psi
Management System: split sec. ftc
Oil Used Since Boost: castro high milage 10w30
Oil Change Frequency: 4,000mi
Knock Sensor
Tires
rear motor mount twice
dog bone twice
piston rings fried
knock sensors
Gas Milage:370-400 to a full tank do the math
jpp header&muffler complete set up
split sec ftc
TRD EBC
TRD THermostat
Jim fuel line
190Walbro
Injen Intake
Cold Air Extension
msd ignition
spec stage 3 clutch kit
fidenza light flywheel
magna core wire
denso ik22 plugs
kaaz LSD 1.5 differ.
twm short shifter
Gregtrd
Postby CamryOnBronze » Wed Nov 28, 2007 8:40 pm
Type of Motor: 1mz-fe
Transmission: Manual
Date Boosted: August 2007
Milage on Boost Date: 92,000 Miles
Current Milage: 103,000 Miles
Daily Driver, Seasonal, Weekend Car or Trailer Queen: Daily Driver (summer only)
PSI: Stock Pulley (4 psi), now 6psi
Management System: None initially, now Apexi SAFC2
Oil Used Since Boost: Mobil 1 5w30 Synthetic
Oil Change Frequency: 3000 miles
217 WHP / 209 WTQ @ 4 psi
230 WHP / 218 WTQ @ 4 psi (added JP exhuaust, fuel pump, jim's fuel mod, and tune with SAFC)
254 WHP / ??? WTQ @ 6 psi (added pulley, supra injectors)
Reason You Thought Your Setup Was The Best Choice For Your Needs:
I wanted to start with all of the basic mods before I installed the supercharger- power is nothing without suspension and braking ability. I wanted a safe, reliable daily driven setup that would perform well without risking engine damage.
After the need hit for more power, I installed a full JP setup, walbro fuel pump, and Jim's fuel mod with an SAFC2 and saw a decent gain with a tune. I then installed Supra Injectors (96-97) and a 6 psi pulley and am now happy with the setup. Hoping that the mileage will still stay decent and the car will remain reliable.
Someone who wants a decently quick car without much hassle or costly install and tuning fees- a fun car to talk about and drive that maintains reliability and driveability, yet still has the power to surprise people.
On 6 psi, Id say about the same thing- its the perfect amount of power for daily use IMO and should hopefully still remain reliable.
OEM clutch (was a cheap ebay clutch installed by the dealer, it couldnt hold the torque of the supercharger)
EGR code, but I am running a blockoff plate.
Gas Milage:
25-30 MPG with a city/highway mix
I plan to run 5.5 psi with a full dyno tune next summer, but this is a great reliable and powerful setup for what it is. The dyno proved that the stock ECU manages the supercharger and AFR well- slightly lean in the low end and slightly rich up top. The curve could be smoothed out some with tuning but looks great for a stock ECU and no tuning.
After adding more boost and further upgrades I am even happier with the setup.
TRD Supercharger
TRD EBC
Injen Intake
Shorter SC belt
JP performance Headers, y-pipe, and catback
Apexi WS2 Muffler
Magnecor Spark Plug Wires
Denso Iridium IK22 Spark plugs
ACT Street Clutch Kit
Fidanza Lightened Flywheel
TRD Oil/Radiator Caps
Pulleyboys 2.8 in Pulley
Jim's Fuel Mod
Walbro 190 Fuel Pump
325 cc Supra Injectors
Apexi SAFC2
Postby no_escape » Fri Feb 22, 2008 12:29 am
Date Boosted: Not sure, ask shocar4(he is the orgional owner)
Milage on Boost Date: ask shocar4
Current Milage: 158,XXX
PSI: 4psi
Management System: Split Second Fuel Calibrator
Oil Used Since Boost: Mobil 1 5w30 Full Synth
Oil Change Frequency: 3,000 - 4,000 Depending on color.
Most Recent Dyno Numbers and PSI: Not sure, this spring I will.
I was tired of my 420a 2ga eclipse and wanted more power. I was looking for a 4g63t 2gb eclipse but there was nothing within 300 miles of where I live. I found the car on facebook for a GREAT price and couldn't say no.
For someone who is looking for power but also wants a car with a decient amount of room front and back, including the boot. Also would like a car that dosent have that cheap plastic look inside.
So far, nothing for me... yet
The temp is SOOO cold here and the car is running lean. I need a wideband and then have it dyno tuned.
Gas Milage:
20-24.5 on 91oct... NO ETHANOL I do 95% highway driving, so I don't know my city mileage.
I want an LSD. I NEED a Wideband for tuning with the Split second software. I plan on having the car dyno tuned once I get a NGK AFX wideband. After she is tuned, I plan on going to the strip for my quarter mile time as well as the new iowa speedway and get my lap time... mainly for shits and giggles
Jim fuel upgrade
190Walbro
305 Injectors
K&N air filter
170 thermo
Greedy Catback exhaust
Split Second fuel calibrator
no_escape
Postby shocar4 » Fri Mar 21, 2008 1:11 pm
Date Boosted:
Current Milage: 127k
PSI: 4psi
Management System: will be getting a SAFC2
Oil Used Since Boost: Mobil 1 Synthetic 10w30
Oil Change Frequency: 3k miles
I just want a sporty car that is going to be very realiable and yet very quick! TOYOTA=reliablility and TRD Sc'er=very quick
someone that demands realiability and loves to hear that supercharger whine when you whined it up!
knock on wood....nothing so far!
Please List Any Service or CEL Codes You Have Had To Deal With Due To Boost: None
Gas Milage:
27-29.5 city/highway
Jim's fuel upgrade
TRD exhaust
TRD short-throw shifter
Injen CAI
NGK IridiumIX
Magnecore 8.5 mm wires
TRD oil cap
shocar4
Postby tacti » Fri Mar 21, 2008 5:41 pm
Induction Type: Turbocharger
Type of Motor: 2az-Fe
Transmission: 4sp Auto
Date Boosted: March 20 2008
Milage on Boost Date: 100,000
Current Milage: 100,150
Boost Kit (or major component brands if custom): Turbonetics Scion tC kit
PSI: 8psi
Management System: Unichip,
Oil Change Frequency: 3,000 (haven't have first oil change yet
Most Recent Dyno Numbers and PSI: 206.29WHP / 204.62tq, 203.72WHP / 207.70 tq @ 8psi
Since scion tc kit was out, and wanted to try it out....
and.... I4 engine does not give me much power, you know...
I really cannot tell yet. I just got this kit a few days ago, and haven't tested out throughly yet.
So far nothing...
[b]Please List Any Service or CEL Codes You Have Had To Deal With Due To Boost:
Nothing.
Gas Milage: not very sure yet..
I just got my car from the shop and having idling issue right now. my hop is still troubleshooting....
-T3/T4 E-50 Ball Bearing Turbo
-Raptor blow off valve
-Evolution wastegate
-Unichip engine management
-K & N filter
-4 drop-in Motron 630cc high flow injectors
-Denso IK22 spark plug
-Currently running on stock cat, but will be replaced with high flow cat soon
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby Mr_Chunkz » Sat Apr 26, 2008 11:02 pm
Type of Motor: 1MZ FE 3.0L V6
Transmission: Automatic
Date Boosted: April 2008
Milage on Boost Date: About 11k
Current Milage: 134,XXX
PSI: 6 PSI
Management System: Apex-i AFC Neo
Oil Change Frequency: 3000 Mi.
Most Recent Dyno Numbers and PSI: 216.5 @5551rpm ( Slipping belt), 250.1 lb/ft Torque @3300rpm @ 5.5PSI
6 psi is an insane kick in the nuts. For anyone that wants to feel an awesome pull go for 6 pounds. Be wary of long term effects..fried my second engine already.
You must have extreme patience and the money to back up with anything past 4 PSI. Check engine lights will be regular for you ( at least they were for me anyway )
Once venturing past 4 PSI the boost becomes addicting. Id like to explore options closer to 10 psi at this point...
Fried a second engine with 6 psi and a heavy foot
Broken Fuel Pump ( No signal coming from pump ) - Replaced with Walbro 190LPH
Threw out a rod bearing, comprimising my first engine block while boosted on 5.5 psi. Replaced with used engine.
Blown knock sensor bank 2, shortly after engine swap.
Blown A/F Sensor Bank 1 and 2, shortly after dyno tune
Blown knock sensor banks 1 and 2 ( Yes... again ) shortly after replacing A/F sensor - Knock sensors replaced with ATS Knock Sensor Kit
A/F Sensor malfunction: Bank 1 Sensor 1, Bank 2 Sensor 1 ( The A/F sensor on each header ).
Knock Sensor Malfunction Banks 1 and 2
Engine lean condition bank 1 - Code went away after a reconditioned engine was dropped in the replace second engine... most likely a code caused by excessive engine blow-by.
Engine misfire cylinder 4 - Most likely caused by blow by from a fried piston, again this code went away after I dropped in another engine.
Gas Mileage: Around 16-20 mpg Mostly City, running 11.7 Air Fuel Ratio @ WOT.
Blew my motor.
Culprit is most likely a bad piston ring causing excessive oil blow-by which finally starved my engine of oil.
Got the new motor in but immediately blew a knock sensor and now fried an A/F sensor.
Got the new A/F Sensors in after replacing the knock sensor on bank 2 and blew both knock sensors. Replaced with ATS Knock sensor kit.
Fried my second engine from boosting 6 pounds and driving with a heavy foot. Replacement engine with all new parts lasted a grand total of 3 months. Replacing stock engine with built motor very soon.
TRD Supercharger, 6 PSI
Injen Short Ram Intake
Custom Cold Air Extension
NGK Resistor Plug Wires
JPP Headers
JPP Y Pipe
JPP 3" Catback With Magnaflow Race Series Muffler
Custom Stainless Steel Test Pipe
Walbro 190 LPH Fuel Pump
Apex-i AFC Neo
Supra 330CC Injectors
Jim's Fuel Mod
TRD 160* Thermostat
ATS Knock Sensor Kit With GM Knock Sensors
MSD DIS-4 Ignition
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby bigbirdSCed » Fri Jun 27, 2008 4:59 pm
Transmission: Auto
Date Boosted: somt time in 05
Milage on Boost Date: 15,000mi ish
Current Milage: 178,340mi
PSI: 4psi
Management System: no tune
Oil Used Since Boost: royal purple 10w30
Oil Change Frequency: 3k miles or 3ish months
Most Recent Dyno Numbers and PSI: 199whp @4psi
good setup for my needs, never liked a stock car. reliable performance as most of us here wanted. plus i like having an odd car. ive only seen one supercharged camry in my area and i like having somthing special.
this a a good setup for someone who wants to add some spice to their daily drive. the auto tranny provides a reliable and comfortable ride especially in traffic but lacks some enjoyment and control. if i were to do this again, or keep the car, ill definatly be going manual.
O2 sensors
fuel pump(not broken but needed to be replaced to keep up)
O2 sensors failure codes
coolant temp sensor codes
lean o2 code on front bank
runs a little rich as a reslut of no tune.
Gas Milage: 23-28/14-18mpg Hwy/city on 93 octane
would like to go to 5.5 psi but worries about the millage on the auto tranny and millage on the engine have kept me from doing it...that and gas prices. i DO wish i had a manual. the auto is sluggish and there are time in certain RPM ranges even under boost the car feels slow. also i have noticed a differance when driving between a CAI and SRI.
TRD S/C 4 psi
Jims fuel mod
190 fuel pump
SRI/custom CAI
DATS style custom Y-pipe2.5"
3" highflow cat
3" catback w/ 3" apexi WS
bigbirdSCed
Return to Forced Induction
Users browsing this forum: No registered users and 79 guests
