SolaraGuy.com • View topic - S-AFC neo, or URD callibration unit?
Postby krook » Tue Nov 28, 2006 12:37 pm
what's better to tune with?
krook
Postby jhenty » Tue Nov 28, 2006 1:59 pm
depends on what your doing and how your going to tune. Personally I'd say the Apexi is best for most applications but the URD has other advantages in some situations as well.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby krook » Tue Nov 28, 2006 2:13 pm
well, i only have a 2.9 pulley, so i'm not gonna get crazy with it. what's the advantage of using the URD unit over the S-AFC neo?
krook
Postby Akfahad » Tue Nov 28, 2006 2:39 pm
I've got the SAFC2 and that works fine for me. It's simple enough and does the job I wanted it to. I've heard that the URD is nice, but it's a little over kill. It allows you to fine-tune a lot better than the SAFC does.
Difference
Postby trd4life » Tue Nov 28, 2006 7:36 pm
URD unit controls fuel AND timing, SAFC controls only fuel. The URD setup is far more effective becaus eof the ability to retard ignition timing based on boost pressure but its a little complicated to use and a bitch to always have the laptop out.
Re: Difference
Postby krook » Tue Nov 28, 2006 7:45 pm
trd4life wrote:URD unit controls fuel AND timing, SAFC controls only fuel. The URD setup is far more effective becaus eof the ability to retard ignition timing based on boost pressure but its a little complicated to use and a bitch to always have the laptop out.
so for my meager, simple setup S-AFC neo should be okay huh?
hey, welcome back btw, Gabe!
krook
Postby DatSRBoi » Tue Nov 28, 2006 7:58 pm
if you want simple, the apexi will do. URD is my recomendation but allot of the shop (In my area at least) never heard of it... Soo if they havnt heard of it, I wouldnt trust them with it.
id gone with the URD myself awhile back if it wernt for the confusion with the dyno tuners in my area.
Postby Eye8Pussies » Tue Nov 28, 2006 8:13 pm
at least you guys have the option of using the urd unit.....damn 02 sensors and lack of a/f sensors... :(
Postby solow1605 » Tue Nov 28, 2006 9:37 pm
I have both and if you're running 5.5 psi the SAFC may not be enough hence my case. I need to get mine put in and get a new knock sensor. Don't make the same mistakes buddy.
2003 Anniversary Edition z06. Black on black...seeexxy
solow1605
Postby Eye8Pussies » Wed Nov 29, 2006 11:18 am
^ why wasn't an safc enough?
the boost under load, but not at WOT was enough to cause problems?
Return to Forced Induction
Users browsing this forum: No registered users and 80 guests
