SolaraGuy.com • View topic - GM KNOCK SENSOR DISCONTINUED...?
Postby krook » Fri Dec 01, 2006 7:50 pm
Twosrus.com no longer makes the GM knock sensor. anyone have the part number so i can look it up elsewhere?
if i can't find a GM knock sensor, what would be an alternative solution?
krook
Postby CASTRO » Sat Dec 02, 2006 1:20 am
wow they are gone now? Good thing I bought me a spare GM + adapter and a spare oem.
CASTRO
Postby Eye8Pussies » Sat Dec 02, 2006 7:19 pm
relocate your sensor
Postby Paladin06Greg » Sat Dec 02, 2006 8:25 pm
Also Greddy sells a component that works great with the OEM sensors.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby krook » Mon Dec 04, 2006 6:16 am
Paladin06Greg wrote:Also Greddy sells a component that works great with the OEM sensors.
what's it called?
krook
Postby Paladin06Greg » Mon Dec 04, 2006 6:42 am
Try this.
http://www.mohdparts.com/emanage/index. ... AGE%20BLUE
and see below
I have one I'm not using.
GReddy e-manage Knock Sensor Adapter #1 - #15900903 ONLY $19*
Prevents retarded timing overcompensation by the ECU in response to the knock reading. Wire to the knock sensor and ground.
Can be used with 6 cylinder and vehicles with two knock sensors, as well.
English Japanese
GReddy e-manage RPM Signal Extraction Adapter #1 - #15900904
For cars with no RPM signal (such as those utilizing the Nissan CAN communication system, this adapter will extract rpm information from the spark signals. Wire into each of the ignition signals on the ECU side as well as the ground.
Can be used with cars possessing up to 6 cylinders.
English Japanese
what's it called?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby shocar4 » Wed Jan 17, 2007 9:55 am
has anybody varified if this is a fix to knock sensor problems?
Paladin06Greg wrote:Try this.
and see below
English Japanese
English Japanese
what's it called?
shocar4
Postby krook » Mon Jan 22, 2007 8:21 pm
maybe i should just relocate my knock sensors. how did everyone else do theirs?
krook
Postby DatSRBoi » Mon Jan 22, 2007 8:37 pm
krook wrote:maybe i should just relocate my knock sensors. how did everyone else do theirs?
http://www.solaraguy.org/viewtopic.php?t=30847
Return to Forced Induction
Users browsing this forum: No registered users and 80 guests
