SolaraGuy.com • View topic - TRD Boost/Rheostat light HELP
Postby DatSRBoi » Thu Dec 07, 2006 7:33 pm
Does anyone have the PDF of the TRD boost gauge installation for a Solara V6? Im asking because I want to know where they run their boost hose to AND where the Rheostat light control wire is located at? Want to make my FINALLY Real TRD boost gauge installation correctly.
where they run the hose through the firewall at according to manufactor setup. Haha. I need to know where the where the hose runs and where the Rheostat light control wire is located at so that I can control the light amount.
Postby CASTRO » Thu Dec 07, 2006 8:31 pm
what the? after taking apart your s/c and doing all the work, the TRD boost gauge gives you trouble? I just tapped the same wire as I did for the indiglo gauges and grounded it.
For the boost port, its on top under the strutbar, should be allready tapped since you had a prev gauge. I just drilled a hole through my firewall for the hose.
CASTRO
Postby DatSRBoi » Thu Dec 07, 2006 8:41 pm
CASTRO wrote:what the? after taking apart your s/c and doing all the work, the TRD boost gauge gives you trouble? I just tapped the same wire as I did for the indiglo gauges and grounded it.
Oh no no no. I mean where they run the hose through the firewall at. Haha. I need to know where the where the hose runs and where the Rheostat light control wire is located at so that I can control the light amount.
Return to Forced Induction
Users browsing this forum: No registered users and 80 guests
