SolaraGuy.com • View topic - System Rich
System Rich
System Rich
Postby Akfahad » Fri Feb 09, 2007 6:49 am
I already know I need to do another dyno tune....but every once in a while I'll throw a system too rich code. Every time I throw it tho, it always comes back as Bank 1, Sensor 1....if the system was too rich, wouldn't it throw it on both banks? Just a general question.
Postby PDX SuperSolara » Fri Feb 09, 2007 3:00 pm
Well, if you have a 6 cylinder, you have 2 banks, the rear is bank 1. The system has seperate wideband sensors for each bank and if just the rear bank is running too rich, then it would set the code for that bank only. I would guess you have an injector spraying too much fuel, one in the rear bank may be defective.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby Akfahad » Fri Feb 09, 2007 3:45 pm
hhmmm....ok, thanks Jim.
Postby DatSRBoi » Fri Feb 09, 2007 4:26 pm
If Im correct it usually throws the code to the first bank it see and your car goes into safe mode so it doesnt pick the other ones. I think the rear bank usually gets it first because its the hottest area so detonation can cause it to come out first.
Return to Forced Induction
Users browsing this forum: No registered users and 79 guests
