SolaraGuy.com • View topic - Boost Guage Problem?
Postby mzfe5speed » Sun Mar 18, 2007 6:41 pm
i hooked up my boost guage, it's T'd into the vacuum hose that goes to the boost actuator. it is a mechanical guage. at idle it reads about -15psi, cruising at 70 it reads about -10psi. the wierd thing is that at full throttle the max reading i get is 0psi, no matter what gear or RPM i pull from. why dont i get the proper reading of 4psi? do i have it T'd into the wrong vacuum line? or what else might be the problem?
Go Camry Go!!!
Was Officially BOOSTED!!
(And Loved It!)
http://www.cardomain.com/ride/2488906
mzfe5speed
Postby DatSRBoi » Sun Mar 18, 2007 7:12 pm
dont tap it there.
Postby mzfe5speed » Sun Mar 18, 2007 7:22 pm
^ok, so where should i tap it?
Go Camry Go!!!
(And Loved It!)
mzfe5speed
Postby Astro » Tue Mar 20, 2007 9:30 am
On top of the s/c there's a screw that you take out and put a 90 degree elbow fitting to attach the line for the gauge.
Postby scdsolara619 » Tue Mar 20, 2007 5:14 pm
look @ the pic
02 SE V6 (S/C) AT
scdsolara619
Postby mzfe5speed » Tue Mar 20, 2007 8:40 pm
^^oh, so that explains the notch in the TRD strut bar!! thanks guys, i'll do that this week!
Go Camry Go!!!
(And Loved It!)
mzfe5speed
Return to Forced Induction
