SolaraGuy.com • View topic - Safe to go wot with the S|C with the mods i have?
Postby Dawgz » Sun May 20, 2007 1:14 pm
I just got the S|C installed, the s\c had 15k miles on it from what i understand, we changed the Oil in the s\c before the install, blasted it with throttle body cleaner, as well as the engine's intake ports when the manifold was off.
we flushed the tranny fluid and put full synthetic now, and cut the pipes of the tranny lines to the radiator and re-routed them to its own cooler in the front behind the lower grill.
I have magnecore 8.5mm spark plug wires, NGK Iridium Spark plugs, getting Jim's Fuel mod installed and also the torque rod.
I have a Greddy Evo II Full CatBack installed, and also a Injen intake + extension.
my question is, with all the things stated above, can i safely go WOT and wat not withought blowing a knock sensor?
Postby ---CAMRAZY--- » Sun May 20, 2007 1:21 pm
No, it is not safe.
Postby Dawgz » Sun May 20, 2007 1:53 pm
---CAMRAZY--- wrote:No, it is not safe.
ok, so wat else would i have to do?
Postby Eye8Pussies » Sun May 20, 2007 3:45 pm
lol..don't listen to him....
you *should* be fine....and the only way to find out is by trying ;)
or get an safcII and hook up the knock sensor alarm as well and see how often it sets if off....if it does it alot, then you know you'll blow if you push it hard
Postby Vampire » Sun May 20, 2007 3:57 pm
I would suggest a 190 L/H Walbro fuel pump from URD and a fuel controller such as an SAFC II. Be sure to richen it up o the top end before you go WOT and tune. No sense doing all your hard work and then blowing the knock sensors cause you are lean on your first run. Good luck.
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby Dawgz » Mon May 21, 2007 8:03 pm
Eye8Pussies wrote:lol..don't listen to him....
how do i hook it up to the "knock sensor alarm"
can u explain?
safe
Postby NRDriver » Mon May 21, 2007 9:36 pm
HAHA
NRDriver
Postby Akfahad » Tue May 22, 2007 6:26 am
can u explain?
Once you get the SAFC 2 hooked up, you have to go into the settings mode on the SAFC 2 and go under KNK or something like that. It'll allow you to change the number the SAFC 2 sets the alarm at. I set mine at 100. Only tripped the alarm once and didn't blow the knock sensor.
On a side note, I know your worried about blowing a knock sensor and question going WOT, but then what was the point of buying the supercharger if your never going to open it up? My .02 cents, but since your worried about it, I'd wait 'till you get fuel rail, then you should be fine. I never waited and got on it once I had it installed and it was fine.
Return to Forced Induction
Users browsing this forum: No registered users and 118 guests
