SolaraGuy.com • View topic - split sec safc vs. apexi safcII...which is better?
Postby hskrsolara » Sat May 26, 2007 11:22 am
Well, I've done a little searching on sg, had a little luck but not much. Plus, it was all seriously old info.
My question to you guys is which unit would you recommend and why? I need to get something to control my air-fuel mixture and know that I need to baby those knock sensors, but which unit do you prefer?
I know the split sec unit is pretty rare but seems to have a little better reviews. However, the safcII has the knock alarm which would be beneficial as well. Hopefully you boosted fellows can provide a little insight.
hskrsolara
Postby Eye8Pussies » Sat May 26, 2007 11:58 am
which one is the split second safc? how is it different from the regular safc?
please enlighten me...
Postby hskrsolara » Sat May 26, 2007 12:42 pm
different brand.
I believe it is all manually adjusted, no digital readout.
hskrsolara
Postby Eye8Pussies » Sat May 26, 2007 1:51 pm
ahhh...so it's basically like the very first version of the safc with the knobs?
I wouldn't see the point of that when you can pick up an safcII for so cheap nowadays
Postby Akfahad » Sat May 26, 2007 6:21 pm
If your refering to the Split Second Fuel Timing Calibrator, like the one sold on URD's website vs. the SAFC II, the SAFC II will be fine. I talked to JoeB about this age's ago when I was upgrading and I fortunately saved some of his PM's in case I needed to refer back to them. Here is what he told me:
"The Split Second is better but it is over-kill for the application if you don't excede 6psi. No need to adjust timing, ECU controlled that just fine plus it's more expensive. The Apexi-SAFC-II is less expensive and a good choice. Plus it gives you the ability to monitor knock and others."
Postby hskrsolara » Sun May 27, 2007 12:25 am
thanks, I was looking for some of gabe's recs since I knew he had it. I will shoot for the safcII.
hskrsolara
Return to Forced Induction
Users browsing this forum: No registered users and 118 guests
