SolaraGuy.com • View topic - Stock Pulley...
Stock Pulley...
Stock Pulley...
Postby Dawgz » Tue Jun 26, 2007 8:52 pm
ok so...heres a pic of my pulley
as i saw on the pulleyboys site, its suppose to be 2.5~3psi, not the 4psi that i thought it was.
Im gonna gun it tomorrow just to see what my max boost is, and what my pulley is putting out, but im pretty sure its around 3psi.
so on pulleyboys.com they have the 3.2" at 2.5~3psi, and a 3.1", 3.0" and so on.
i was wondering if i should get the 3.1" to be close to 4psi.
Postby Dawgz » Wed Jun 27, 2007 12:36 am
also, if i get the 3.1" will a regular pulley puller a shop has do the job or do i need something special?
just unbolt, use the pulleypuller, take it off, pop the new one in, slip the belt over and adjust the alternator to tension the belt correct? (i dont have an automatic belt tensioner)
Postby Eye8Pussies » Wed Jun 27, 2007 10:05 pm
^ yup, exactly that....or even just a mallet and you can tap out the old one
Postby Dawgz » Thu Jun 28, 2007 11:40 am
so what i thought was true, i got on it today and my boost gauge showed me 3psi max
and here is what the safcII caught (max numbers of throttle/rpm durring 3psi)
and this is at idle...i dono if this matter but ill just put it on here...
Postby Akfahad » Thu Jun 28, 2007 1:07 pm
don't know if the SAFC will record your Correction number, but was the correction ("Cor") reading something other than "0" when you got on it?
Mine adjusts based on throttle response/position. At idle, my correction varies from 3-4 and at full throttle, the correction goes up to 18, or there abouts.
Postby Dawgz » Thu Jun 28, 2007 2:25 pm
Akfahad wrote:don't know if the SAFC will record your Correction number, but was the correction ("Cor") reading something other than "0" when you got on it?
yes, it was correcting it, and no the safcII doesnt save that info.
At idle, my correction is +- 0, i didnt look at it when i get on it, ill see next time.
Postby Dawgz » Fri Jun 29, 2007 6:57 pm
Can someone please post a picture of their 4psi pulley?
Postby Paladin06Greg » Fri Jun 29, 2007 7:15 pm
FYI -
NEW TRD SUPERCHARGERS
http://www.toysport.com/New%20Products/ ... argers.htm
Keep in mind that boost is NOT just a factor of the pulley size. Air temp, air density, altitude and other factors all play a role.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Dawgz » Fri Jun 29, 2007 7:27 pm
another member on here was saying the older pulleys (mine) were not giving out 4psi...
Postby Paladin06Greg » Fri Jun 29, 2007 7:38 pm
I've got a slightly used 2.8, if you like.
Dawgz wrote:another member on here was saying the older pulleys (mine) were not giving out 4psi...
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Paladin06Greg » Fri Jun 29, 2007 7:40 pm
Note the chart says MAX boost not exact boost.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Paladin06Greg » Fri Jun 29, 2007 7:49 pm
It's best to use a pulley puller. DON"T beat the damn thing off as you will hurt something.
Eye8Pussies wrote:^ yup, exactly that....or even just a mallet and you can tap out the old one
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Dawgz » Fri Jun 29, 2007 10:54 pm
Paladin06Greg wrote:I've got a slightly used 2.8, if you like.
a 2.8 is what....6psi? im not looking to boost that high, i want a 4psi pulley, do you have that? Ill gladly buy it off of you if so.
Postby hskrsolara » Sat Jun 30, 2007 5:31 am
now that you have your fuel mods, why not go 5.5?
hskrsolara
Postby Paladin06Greg » Sat Jun 30, 2007 7:42 am
Sorry all the pulleys I have are higher not lower boost.
Paladin06Greg
Torqued Solara
Torqued Solara
Return to Forced Induction
