SolaraGuy.com • View topic - SAFCII Correction number...
Postby Dawgz » Sat Jul 14, 2007 9:21 pm
So i was watching the Correction it was making, and the most it ever did was 5, when i floor it... shows Cor 5 or something along those lines...i was wondering what some of you have read on ur SAFCII.
Postby Dawgz » Sat Jul 14, 2007 9:26 pm
Akfahad posted in my other thread (about something else) but had to do with the SAFCII, he wrote:
Akfahad wrote:Mine adjusts based on throttle response/position. At idle, my correction varies from 3-4 and at full throttle, the correction goes up to 18, or there abouts.
...but my idle it shows Cor as 0, but when i get on it, the Correction increases and wat not, with a max value of about 5.
Re: SAFCII Correction number...
Postby DatSRBoi » Sat Jul 14, 2007 9:27 pm
Dawgz wrote:So i was watching the Correction it was making, and the most it ever did was 5, when i floor it... shows Cor 5 or something along those lines...i was wondering what some of you have read on ur SAFCII.
If your talking about what I believe so, every car is different. That means on the setting the dyno tuner did they are adding/taking away 5 at most so on your gauge it will only go up to that much only. My car was all the way to 8 or 9 so on the gauge it will only correct it up to 9 and never over. Then again I had huge injectors so I my safc was set to take away more fuel.
Return to Forced Induction
