SolaraGuy.com • View topic - Header Removal with the S|C on?
Postby Dawgz » Mon Aug 20, 2007 12:54 am
Is it possible to Remove the Rear header from under the car (on a lift) and to not touch the supercharger (not taking it off)
is this possible? any tips? tricks?
Postby JavaJoe_2 » Mon Aug 20, 2007 4:16 am
Yeah, no problem.
If you're doing stock headers, rotate them, they will come out by the driver's side axle.
If you want quicker, loosen motor mounts, and lift engine forward.
1" should be good.
Got Boost?? :sweet:
JavaJoe_2
Postby Dawgz » Mon Aug 20, 2007 9:25 am
thanx bro. Ill tell my mechanic this.
Return to Forced Induction
