SolaraGuy.com • View topic - FLYWHEEL INSTALL???
FLYWHEEL INSTALL???
FLYWHEEL INSTALL???
Postby netherland24 » Sat Sep 15, 2007 11:17 am
has anyone had problems with thier fidenza flywheel putting it on cause of size???? mine seems to be thicker then OEM and isnt work any ideas
thank you VERY MUCH
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby hskrsolara » Sat Sep 15, 2007 11:21 am
i've never heard of this happening...are you installing it or is a mechanic?
hskrsolara
Postby Eye8Pussies » Sat Sep 15, 2007 12:50 pm
I have a Spec flywheel, which is apparently identical to the fidanza one....
and mine "fit" fine during installation, but the teeth catches and grinds on the starter during starts. It makes a loud metal grinding noise (the sounds hurts) only on start up and then goes immediately away.
I thought it was my gen3 starter, but even replaced with a gen4 starter (which is basically identical- just different wiring spots) it still did it.
Not sure why it does it. But I've learned to live with it until it causes a real problem.
Postby netherland24 » Sat Sep 15, 2007 1:24 pm
shop...
00 SS Lara 277hp
netherland24
Postby CamryOnBronze » Sat Sep 15, 2007 2:37 pm
I had my fidanza flywheel installed 2 weeks ago and the shop didnt say anything was out of the ordinary... havent noticed a grinding or anything, thats strange...
Postby Eye8Pussies » Sat Sep 15, 2007 3:17 pm
^ I'm thinking that it may be specific to the gen3....but I have no idea...I torqued everything to absolute spec when I installed everything as well as used the locktite as needed....
I've learned to live with it....
and one possible thing as well is that my flywheel is 9lbs (it was shipped and with the bearing, packaging, etc it was a shipped 10lbs weight) so it seems to be the mr2 flywheel
even though the 11lbs camry/solara flywheel is supposed to be interchangeable, it may be the cause...I have no idea....
Postby netherland24 » Sat Sep 15, 2007 5:39 pm
im worried they sent me a 2.2 flywheel those bastards... :(
now i have to delay my car even longer
00 SS Lara 277hp
netherland24
Postby netherland24 » Sun Sep 16, 2007 10:08 pm
any ideas?
00 SS Lara 277hp
netherland24
Postby Eye8Pussies » Mon Sep 17, 2007 2:16 pm
no idea....but if you're doing it at a shop, they should know...otherwise, what are you paying them for??
and I'm not sure why a 4banger flywheel would be thicker than a v6 one anyway....
if you really want to find out, get the part number and call the company. or go to a junkyard, grab a stock 4banger one and then compare
Return to Forced Induction
