SolaraGuy.com • View topic - Is 200whp where i should be at? on my auto tranny?
Postby Dawgz » Wed Sep 26, 2007 10:07 am
My solara dynoed at 200whp and 208torque, im on 5.5psi of boost and i have the auto tranny.
Is 200whp where i should be? if not then what?
i know i can gain a bit more power by getting that new fuel pump, because the dynoshop "de-tuned" it to run a bit safe because with everything maxed out, the car was running real lean at the top end. So they suggested to install a higher rated fuel pump and then come back to retune.
but what numbers should i be aiming for right now?
Postby woa_its_j3ff » Wed Sep 26, 2007 10:09 am
well I think when they say Solara having 200 hp stock, i think that's at crank. are you saying now you are putting down 200 at the wheels? that .. seems about right
Postby Dawgz » Wed Sep 26, 2007 10:11 am
woa_its_j3ff wrote:well I think when they say Solara having 200 hp stock, i think that's at crank. are you saying now you are putting down 200 at the wheels? that .. seems about right
yea, i know its rated at 200 @ the crank, im puttin 200 at the wheels.
Postby Dawgz » Wed Sep 26, 2007 10:12 am
Postby woa_its_j3ff » Wed Sep 26, 2007 10:14 am
for an autotranny I would think that you are running about right. try getting that fuel pump and see what it does?
Postby Midias » Wed Sep 26, 2007 11:15 am
sounds good to me man I think a stock auto puts out 135 whp
Postby Stark33 » Wed Sep 26, 2007 11:18 am
stock how much horsepower am i running 99sle v6
Stark33
Postby Dawgz » Wed Sep 26, 2007 11:21 am
Stark33 wrote:stock how much horsepower am i running 99sle v6
manual or auto?
I believe its 155whp on manual and 135-140whp on auto.
Postby Stark33 » Wed Sep 26, 2007 11:28 am
auto
Stark33
Postby Midias » Wed Sep 26, 2007 11:37 am
Stark33 wrote:auto
Midias wrote:sounds good to me man I think a stock auto puts out 135 whp
manual or auto?
Postby Dawgz » Wed Sep 26, 2007 11:42 am
man, the stock numbers are sad.
Postby Midias » Wed Sep 26, 2007 11:46 am
Your car is doing great on HP for an auto dawgs you should be proud.
Return to Forced Induction
