SolaraGuy.com • View topic - Boost port hooks to?
Postby free » Wed Oct 03, 2007 1:48 pm
I'm trying to figure out what the boost port, which is on top of the supercharger, hooks up to so that my piggy back can read the boost. Can someone inform me?
Thanks
free
Postby ---CAMRAZY--- » Wed Oct 03, 2007 1:58 pm
It hooks up to The hose on your boost gauge, what do you mean by Piggy back??
Postby free » Wed Oct 03, 2007 2:27 pm
By "piggy back" I mean my URD (split second) air/fuel ration calibrator and fuel/timing controller.
boost gauge? Hmm, I'm not sure I follow. I know that a boost gauge would be installed on your A-pillar and the boost line would go to it. But, I don't have a gauge, so is there also another place to connect it. In order to tune your ECU (via the piggy back) would have to be able to read boost.
free
Postby JavaJoe_2 » Wed Oct 03, 2007 7:03 pm
You could try right underneath the strut bar in the center of the s/c'er. You'll find a allen head used for people that use a boost gauge. Personally I would call URD to find the best info...we're all guessing. :o
Got Boost?? :sweet:
JavaJoe_2
Postby ---CAMRAZY--- » Wed Oct 03, 2007 7:35 pm
Seriously^^^ I want to know too.
Postby shocar4 » Wed Oct 03, 2007 7:47 pm
free....where are you located?
shocar4
Re: Boost port hooks to?
Postby Gregtrd » Wed Oct 03, 2007 9:13 pm
free wrote:I'm trying to figure out what the boost port, which is on top of the supercharger, hooks up to so that my piggy back can read the boost. Can someone inform me?
Thanks
you could tee it off with your boost port on the charger. i relocated my boost port about an inch back so the strut bar wouldnt hit the boost tee. i got a split sec as well.
Gregtrd
Postby Dawgz » Wed Oct 03, 2007 10:05 pm
Thanks
can u take a picture on how u did that? please?
Postby free » Thu Oct 04, 2007 8:16 am
shocar4 wrote:free....where are you located?
I'm in L.A. I'm going to have someone do it for me, but I was trying to figure it out for myself first.
free
Postby free » Thu Oct 04, 2007 8:18 am
Thanks
Interesting. It sounds like that's the solution. For some reason I'm having a hard time picturing it. I should have it hooked up today or tomorrow and I'll try and take a pic.
free
Postby CASTRO » Thu Oct 04, 2007 8:24 pm
i have the URD unit as well. it forces the ECU to go open loop mode as soon as it hits the specified amount of boost
in short: it intercepts the two O2 sensors signal and once it hit boost, it sends a signal that the O2 sensors would have otherwise to get the ECU into open loop and have it stop trimming fuel.
On mine, i just used a brass T fitting between my boost gauge and the URD box.
CASTRO
Postby free » Thu Oct 04, 2007 8:30 pm
Well, a spout fitting was screwed into the boost port, which is on top of the supercharger. Then a hose is connected from it to the URD box. I guess I should have been able to think that one out, but oh well.
I'll get it tuned again next week and hopefully all will go well.
free
Return to Forced Induction
