SolaraGuy.com • View topic - SC minus EGR....
SC minus EGR....
SC minus EGR....
Postby ---CAMRAZY--- » Wed Oct 31, 2007 4:24 pm
Who here has/is running their SCed 1MZ with their EGR blocked off using a resistor for "No CEL"??
Postby Eye8Pussies » Thu Nov 01, 2007 8:54 am
me since the very beginning
Postby Patrik » Fri Nov 23, 2007 11:55 pm
and that would be better ?
1999 SE V6 5 speed SOLD
Patrik
Postby Dawgz » Sat Nov 24, 2007 12:07 am
less heat back into ur intake!
Postby ---CAMRAZY--- » Sat Nov 24, 2007 12:45 am
Other than King, anyone on a solara or gen4 camry?
Postby Sebas007 » Sat Nov 24, 2007 5:46 am
Dawgz wrote:less heat back into ur intake!
Yep the purpose of the EGR valve is to recirculate exhaust air but what happen in cold weather in NJ (not talking of your Cali...Milt !! :evil: ). Does the EGR valve is just for a economic and environmental purpose ?? I know, controlling by the ECU the EGR valve redirect hot exhausted gas in the chamber to maintain a minimal temp to minimize the explosion heat and ping.
Hey just got something from a wiki that back my thoughts
The design challenge The EGR system of today must precisely control the flow of recirculated exhaust. Too much flow will retard engine performance and cause a hesitation on acceleration. Too little flow will increase NOx and cause engine ping. A well-designed system will actually increase engine performance and economy. Why? As the combustion chamber temperature is reduced, engine detonation potential is also reduced. This factor enabled the software engineers to write a more aggressive timing advance curve into the spark timing program. If the EGR valve is not flowing, onboard diagnostics (OBD) systems will set a code and the power control module (PCM) will use a backup timing curve that has less advance to prevent engine ping. Less timing advance means less performance and economy. Do your customer a favor and fix those EGR codes that you may have previously deemed as unimportant.
When fuel and oxygen are mixed, they burn to expand and produce heat. Too much oxygen and the amount of heat goes way up, burning valves and pistons. Bu allowing a controlled amount of burned gasses to recycle back into the engine, the temperature can be controlled and preserve valves and pistons while burning a minimum amount of fuel.
EGR stands for Exhaust Gas Recycling. If you EGR valve is not functioning properly it can result in poor performance, diminished fuel economy and potential harm to the engine.
EGR Theory. EGR serves one purpose and one purpose only. That purpose is to reduce Oxides of Nitrogen (NOx). Undernormal combustion, Nitrogen(N2)Oxygen (O2) in the air and Hydrocarbons (HC) in the fuel combind into water(H2O) Carbon dioxide (CO2) and the Nitrogen remains unchanged. Under very hot combustion temperatures, the Nitrogen reacts with the other two byproducts and forms Nitrogen oxide (NO). After being released into the atmosphere, it picks up another Oxygen and becomes Nitrogen dioxide (NO2). In the presence of sunlight,
it combines with other compounds like Hydrocarbons and forms Smog. Since exhaust gas is inert (very stable) it doesn't burn again. So by being introduced into the combustion chamber, it will lower combustion chamber temps enough so that the Nitrogen doesn't react with the other compounds and is passed unchanged out the tailpipe thus not contributing to smog. Now, since exhaust gas doesn't burn, it doesn't exactly help with combustion. At higher RPM's, this really isn't noticable, but at idle, the reintroduction of exhaust gas will cause a very rough idle and can cause stalling if to much is introduced into the combustion chamber
Bottom line I think if you don't get any CEL by installing a resistor or something it probably work "normally" regarding the performance curve but I think you would have big high temp issue especially boosted ?? Examining this and I don't see how you can solve the high temp problem...a intercooler would just make more fresh air to heat up but in the other hand the intercooler purpose is to cool down intake air when compressed to avoid knocking or ping in the combustion chamber...my opinion is that the performance will be maybe a bit better but your setup will not be realible. Now that King did it...he may answer the question of high temp and how he solved it !
Postby JavaJoe_2 » Sat Nov 24, 2007 6:17 am
I wonder why the Sienna vans don't run one?
Got Boost?? :sweet:
JavaJoe_2
Postby ---CAMRAZY--- » Wed Dec 05, 2007 9:09 am
Eye8Pussies wrote:me since the very beginning
King, are you using a resistor for no cel?
Postby CamryOnBronze » Wed Dec 05, 2007 9:17 am
i have a blockoff plate that goes on the supercharger since mine was a kit for the sienna if you want it milt... Ive got no use for it.
Postby Dawgz » Wed Dec 05, 2007 10:11 am
CamryOnBronze wrote:i have a blockoff plate that goes on the supercharger since mine was a kit for the sienna if you want it milt... Ive got no use for it.
Contact Rj, he might want it as well.
Postby ---CAMRAZY--- » Wed Dec 05, 2007 10:25 am
PMed....
Postby DatSRBoi » Wed Dec 05, 2007 11:08 am
You have a 1MZ or 3MZ? I have not look into it since I do not really mod any more of them for now but see if they are imported over seas. Usually over seas model do not have EGR. Maybe you can see how they do it. I know over sea supras do not have EGR set up unlike the US specs.
(I know solara are not over seas but the camry and es300 are for sure as well as the minivans)
Postby 99V6solaraSE » Wed Dec 05, 2007 8:50 pm
yea if he doesnt get it from u.. i might need that...
99V6solaraSE
Return to Forced Induction
