SolaraGuy.com • View topic - What did you do to bend the A/C Line to clear the S/C??
Postby DaTwUnKrAziEpInOy » Fri Nov 09, 2007 12:10 am
I'm in the works of installing the supercharger and I'm wondering what did you do to bend the A/C line ? I just don't want to force bend the line and break it or pinch it.
DaTwUnKrAziEpInOy
Postby PhreakdOut » Fri Nov 09, 2007 12:17 am
How much do you need to bend? I haven't seen the exact situation you speak of but I might recommend making small adjustments over several sections as opposed to a single bend. Take a look at a brake line bender. It's a hand too that bends the tube around a radius. This keeps the line from kinking.
Example: This is a tool for bending AC lines.
Postby DaTwUnKrAziEpInOy » Fri Nov 09, 2007 1:40 am
I need to bend the line that's comming out of the passenger side firewall. When I put the charger on, it sits right on top of that A/C Line. But that tool that you mentioned might just do the trick.
DaTwUnKrAziEpInOy
Postby JavaJoe_2 » Fri Nov 09, 2007 6:05 am
It just needs to be pushed a little to the side. Install everything and go from there. If it hits, push it, check again. It doesn't need to go far.
Got Boost?? :sweet:
JavaJoe_2
Postby DatSRBoi » Fri Nov 09, 2007 7:36 am
Do not bend it. Just pull it to the side. It is suppose to clear I believe. If not zip tie it out of the way.
Postby Gregtrd » Fri Nov 09, 2007 8:28 pm
DaTwUnKrAziEpInOy wrote:I need to bend the line that's comming out of the passenger side firewall. When I put the charger on, it sits right on top of that A/C Line. But that tool that you mentioned might just do the trick.
if the ac line is too close to the supercharger pulley you should check your rear motor mount, it might be bad. it seems that i have to replace that every 6 months theyre to soft. if you have a strut bar youll be able to see the engine leaning towards the right.
Gregtrd
Postby CamryOnBronze » Sat Nov 10, 2007 9:31 am
I just went ahead and moved it slightly by pulling it. I also put a couple layers of thick two sided tape on the line where it rubs the S/C unit and havent had any issues with it so far.
Postby JavaJoe_2 » Sat Nov 10, 2007 9:35 am
Remember the engine mounts will still let the engine move a bit.
You should have a gap inbetween the two. Look for a shine or chaff on either of them.
Got Boost?? :sweet:
JavaJoe_2
Postby Dawgz » Sat Nov 10, 2007 9:42 am
what we did was u hold the ac line with ur right hand, with the cap in the middle between ur middle and index finger, and then slowly push towards the firewall, itll slowly bend it twards that.
Thats what the s\c install manual calls for and thats what the toyota mechanic i trust instructed.
Postby JavaJoe_2 » Sat Nov 10, 2007 8:10 pm
Got Boost?? :sweet:
JavaJoe_2
Postby DaTwUnKrAziEpInOy » Sat Nov 10, 2007 11:35 pm
Cool....thanks for the info everyone
DaTwUnKrAziEpInOy
Return to Forced Induction
