SolaraGuy.com • View topic - Spark Plug Info
Spark Plug Info
Spark Plug Info
Postby Sp33d » Wed Dec 19, 2007 12:32 pm
Alot of us are running IK22's for upgraded spark plugs once supercharged.
However, it has dawned on me that some might not have the right gap on our spark plugs.
i was about to just buy the first denso iridium ik22's that i saw on ebay. not so. the gap in our stock spark plugs is .044, many spark plugs that have the ik22 name have gaps of either .032 or .035(considered normal). yes, the difference may seem minuscule, but when you are dealing with 1/100ths of a number, each bit counts. In this case, .012.
i did some research and what are the benefits of each circumstance?
* narrow-gap risk: spark might be too weak/small to ignite fuel;
* narrow-gap benefit: plug always fires on each cycle;
* wide-gap risk: plug might not fire, or miss at high speeds;
* wide-gap benefit: spark is strong for a clean burn.
so, essentially, you have two choices. if you just pull any spark plug off of ebay, you will most likely end up with the smaller gap (.032 or .035) and not burn off all the fuel you give the engine completely. Thus negating the effects of jim's fuel mod OR
two. buy the .044 gapped plugs and you will burn off all the fuel given to the engine.
a direct replacement with a gap of .044 would be for you guys to look up spark plugs for a 2.5L Volvo S80. GOOD LUCK!
Sp33d
Postby CamryOnBronze » Wed Dec 19, 2007 9:12 pm
I wonder which ones Im running... Im guessing th .044 since I have not had a single issue and the car idles and pulls beautifully... I didnt even install the jim's fuel mod yet and havent had any issues, so i would assume theyre fine. Ill check the boxes when I get back to school. But I did read in my haynes manual that it is bad to gap iridium plugs, so I just threw them in and it ran well. Ill see what i can find out, good info!
Postby 99V6solaraSE » Wed Dec 19, 2007 9:21 pm
weird.. on my boxes of ik20s.. it just says 0.4mm
is it safe to assume that its just about right? I havent experienced any problems so far.
99V6solaraSE
Return to Forced Induction
