SolaraGuy.com • View topic - sc'er belt!
sc'er belt!
sc'er belt!
Postby shocar4 » Fri Dec 28, 2007 11:14 am
i know that this has been discussed a million times, but i am running stock 4psi boost and plan on staying there for a while, but i am going to install a new sc'er belt as i do all my maintanance this winter...my question is can i go with the Dayco polycog belt #5060880 for the 5.5 pulley with my stock 4psi pulley or should i just get the 5060885? just trying to get away with having to buy a different belt later on if i decide to go to 5.5 down the road! will the 880 even fit with my stock pulley? ps...i have the earlier style idler plate...ie no dynamic tensioner!
shocar4
Postby CamryOnBronze » Fri Dec 28, 2007 11:34 am
I think you want to run a 88.2" belt. I had the 4 psi pulley with the non-dynamic tensioner setup and the dayco 88.5" belt was too long- I couldnt get enough tension on it for some reason. I went to an auto parts store and got either an 88.1 or 88.2" belt (I think it was for a jeep application) and that fit perfectly. Just ask for a 6 groove belt as close to 88" as possible, but no smaller- i think I bought an 87.7" belt as well and it was too short- but would work for 5.5 psi I believe. I can check the exact belt lengths when i get back to my apartment for you.
Good luck!
Postby shocar4 » Fri Dec 28, 2007 11:45 am
thanks damon! i have a place here in town that carries the daco polycog...so i will run by there and check...not sure if they have the actuall length on there....maybe that is what the last digits of the part # are....not sure.....i know that stock i have a 5060885 and the 5.5 is the 5080880....
shocar4
Postby shocar4 » Mon Dec 31, 2007 6:22 pm
well i picked up a 880 dayco belt and 4 oz. of GM sc'er oil...all that i need now is the ik22's and some magencor wires and i will be all ready to start my winter tune up! i already have the hood off the car, so i can't wait to get started!
shocar4
Postby CamryOnBronze » Tue Jan 01, 2008 6:52 pm
yep the last numbers are the belt length, so you should be good to go!
SC belt
Postby cartang » Wed Jan 02, 2008 7:49 am
I use the stock SC belt , in 2002 I changed the 4 psi pulley to 6 psi same belt I check the tension every year , alway is 90 pounds of tension.
Camry 99, Manual , SC 6 PSI, Jim fuel sistema upgrade / Walbro 190 gph, Eibach, tokico set up , Whiteline F and R bars, Quick shifter, TRD body kit, Ichibahn pedal set. Jim torque coverter
cartang
Postby shocar4 » Wed Jan 02, 2008 7:51 am
sweet good to know!
shocar4
Return to Forced Induction
