SolaraGuy.com • View topic - Cali spec...wtf
Cali spec...wtf
Cali spec...wtf
Postby bigbirdSCed » Tue Jan 08, 2008 2:43 pm
hey guys, problems again :( . after replacing my fule filter and o2 sensors the codes went away and all was well till about 3 days ago. codes came back, bank 1 sensor malf, slow response and a cat efficency code.
after just screwing around with the vin# it say that the car was supposed to be cali spec emissions. today while poking around the engine bay i inspected the sticker under the hood only to find that there was a non cali spec sticker placed over the cali spec sticker :-? i didnt know u could even get thoes stickers.
from what i can tell i now have to go back and buy new o2 sensors for cali spec. but im not fimiliar with cali/non-cali emission camrys (never owned or worked on one...till now). i did pick up some bosch fusion plugs today so thoes will be replaced. im in the dark as to what all i may need to consider or know since its cali spec. thanks for any help or advice.
bigbirdSCed
Postby unbalancedwood » Tue Jan 08, 2008 2:54 pm
cali spec has a/f sensors not o2 right....?
unbalancedwood
Postby bigbirdSCed » Tue Jan 08, 2008 2:56 pm
that im not sure about, but i do know that the 97 camry has o2 sensors then in 98 they stitched to A/F . whether thats different on the cali sopec im not sure.
bigbirdSCed
Postby agent007 » Tue Jan 08, 2008 2:58 pm
maybe why i get the CEL for a lil while then it goes away as i posted in the gen 1 solara section...i know that my mz has the a/f sensors...they are on the exhaust manifolds and they look like o2's but slightly different and can be easily confused...had to buy them from the dealer and it cost over 300 and thats getting them at the dealer price...
01 solara v6 se
trd kit, trd rims, trd suspension
greddy evo cat back
c/f hood
agent007
Postby Dawgz » Tue Jan 08, 2008 3:10 pm
my cali spec solara has a/f sensors....not 02.
Im pretty sure all cali spec cars are A/F sensors.
Postby Turbosolara » Tue Jan 08, 2008 3:22 pm
how many wires does the original oxygen sensor? if it is AF sensor than it has 4. or, just have dealer run your vin number and let them tell you what part you need. (from part department not the service department, service department will give you bullshits)
Postby unbalancedwood » Tue Jan 08, 2008 3:43 pm
I think wether its an 02 or A/F sensor it has four wires...
PS, what bosch plugs do you have? Spark plugs? i think its been said that they dont function correctly on the 1mz...most of us have denso or ngk
unbalancedwood
Postby bigbirdSCed » Tue Jan 08, 2008 3:52 pm
agent007 wrote:maybe why i get the CEL for a lil while then it goes away as i posted in the gen 1 solara section...i know that my mz has the a/f sensors...they are on the exhaust manifolds and they look like o2's but slightly different and can be easily confused...had to buy them from the dealer and it cost over 300 and thats getting them at the dealer price...
the bungs are the same though right? the o2 sensor i put on the rear bank(bank 1 i think) had a much longer wire harness but the sensor itself looked the same.
bigbirdSCed
Postby CASTRO » Tue Jan 08, 2008 9:08 pm
97 cam here with 02 sensors. non-cali spec
CASTRO
Postby Dawgz » Tue Jan 08, 2008 9:18 pm
o2 sensors on a cali spec that requires a/f sensor is gonna end up in bad gas milage, and possible weird fuel usage.
Postby bigbirdSCed » Tue Jan 08, 2008 9:44 pm
but would that explain the dropped codes? what i found weird was that the o2 sensor codes were just on bank 1. i am also getting bad gas millage :-? other then that its idleing a slightly rough from time to time and if i run in in high rpms i can smell unburnt fuel(running rich)
bigbirdSCed
Postby CASTRO » Tue Jan 08, 2008 11:21 pm
im sure that the ecu is running in some sort of fail-safe mode. when that happens, it dumps more fuel in as a precaution which hurts power as well as inclreases fuel consumption. I'd get it replaced if you do need af sensors.
CASTRO
Postby Dawgz » Tue Jan 08, 2008 11:24 pm
also if its dumping more fuel, ur probably fouling ur NEW sensors, get them out asap...and get the A/F ones in there.
Contact adam, he can get them cheaper.
I baught denso ones from Toyota, i dono how much i paid, it was alot tho, i think like $220?
Postby bigbirdSCed » Wed Jan 09, 2008 8:14 am
yeah im gonna have to swap these out asap. im really hoping i havnt fowld my cat :-? .
on and i got bosch platum (iridium) fusion plugs. they no good?
bigbirdSCed
Postby Dawgz » Wed Jan 09, 2008 9:12 am
bigbirdSCed wrote:yeah im gonna have to swap these out asap. im really hoping i havnt fowld my cat :-? .
if u wanna make 220+whp (from our past convos), ur gonna wanna switch out ur stock cat anyway...
Return to Forced Induction
