SolaraGuy.com • View topic - actuator
actuator
actuator
Postby 99V6solaraSE » Wed Jan 09, 2008 8:28 pm
so upon receiving my supercharger i found the actuator to be broken.
http://img.photobucket.com/albums/v437/ ... C02767.jpg
i managed to force it back in.
http://img.photobucket.com/albums/v437/ ... C02781.jpg
http://img.photobucket.com/albums/v437/ ... C02783.jpg
http://img.photobucket.com/albums/v437/ ... C02782.jpg
But is that still safe to run? i feel like itll eventually come off again. Would it be possible to glue, tape, or further support it somehow?
PSE said they could help me out with that. By either replacing it or repairing it. BUt had since i got it in, i had to make sure if it was necessary or not.
99V6solaraSE
Postby JavaJoe_2 » Thu Jan 10, 2008 6:10 am
Are those rivets holding it on the bracket? If so, can you drill them out and replace them?
Got Boost?? :sweet:
JavaJoe_2
Postby 99V6solaraSE » Thu Jan 10, 2008 7:38 am
http://img.photobucket.com/albums/v437/ ... C02773.jpg
nah its just plastic thats part of it. Its not pieces that u can take off or anything. I guess it was just pressed in somehow. Not sure.
99V6solaraSE
Postby shocar4 » Thu Jan 10, 2008 7:47 am
if it was me, i would use a small amount of apoxy around the edges and then press it back together and let it setup!
shocar4
Postby Dawgz » Thu Jan 10, 2008 11:23 am
^ or jbweld around the edges, that would be a better hold.
Postby Eye8Pussies » Thu Jan 10, 2008 7:39 pm
wouldn't think it'll be a problem
the most important part is to test it to see that it holds vacuum pressure
Return to Forced Induction
