SolaraGuy.com • View topic - S/C Idler Plate Assy Cracked....
Postby scdsolara619 » Mon Jan 28, 2008 12:32 pm
Well, I pulled the idler assy off this weekend to replace the belt & tensioner and found the plate that mounts the tensioner is cracked. Of course that item has been discontinued according to TRD and Toyota so I have to have a local machine shop fabricate that plate. I guess from all the vibration from the tensioner it finally started to crack and is getting worse. Has anyone else had this happen? Thanks in advance.
02 SE V6 (S/C) AT
scdsolara619
Postby Eye8Pussies » Mon Jan 28, 2008 12:51 pm
wow...never even heard of that...
and why not get it welded?
Postby DatSRBoi » Mon Jan 28, 2008 1:33 pm
This is new.........
And scary.
Postby scdsolara619 » Mon Jan 28, 2008 1:59 pm
Eye8Pussies wrote:wow...never even heard of that...
Well the way it's cracked I don't want to take any chances, plus I'll have them cut it out of stronger and less flexing material. In my opinion the way that tensioner is bolted to "1" plate that actually flexes is a bad design, but I'm not about to go reinventing the wheel.
02 SE V6 (S/C) AT
scdsolara619
Postby unbalancedwood » Mon Jan 28, 2008 2:03 pm
Dawgz said someone was gonna do this in the future, but you may find yourself in a lucrative position. I was about to buy a S/C but it didnt have the idler assembly. Make a few & sell them!
unbalancedwood
Postby Midias » Mon Jan 28, 2008 2:29 pm
How about some pics you have any.
Postby scdsolara619 » Wed Jan 30, 2008 7:32 am
Midias wrote:How about some pics you have any.
I used to have the free Imagestation account but they are closing now, can't really find any other sites like that, unless someone can tell me, then I can upload the pics and post them, unless there is another way to do it. Thank you.
02 SE V6 (S/C) AT
scdsolara619
Postby unbalancedwood » Wed Jan 30, 2008 7:34 am
imageshack.us
unbalancedwood
Postby Midias » Wed Jan 30, 2008 7:42 am
Use photobucket
Postby scdsolara619 » Wed Jan 30, 2008 7:43 am
unbalancedwood wrote:imageshack.us
Thank you!
02 SE V6 (S/C) AT
scdsolara619
Postby scdsolara619 » Wed Jan 30, 2008 7:44 am
Look by the alternator bolt (very top hole)---(about 4" long crack, both sides)
02 SE V6 (S/C) AT
scdsolara619
Postby Sentinel » Wed Jan 30, 2008 8:41 am
While your situation is too far gone, If I had a S/C I would immediately inspect this area for cracks, and if I found one that was reasonable (1" or less in length?) I'd stop drill it and put it on my inspection checklist.
Sentinel
Return to Forced Induction
