SolaraGuy.com • View topic - Belt rubbing - rubber shavings all over alternator...
Postby scdsolara619 » Tue Feb 19, 2008 6:57 pm
Hi,
I just installed a new tensioner along with the Dayco Polycog belt and I can see rubber shavings on the alternator. I believe (not sure 100%) that the belt is rubbing on the tensioner itself. Do you think if the belt was just a little longer than original that it would actually rub there. I need to investigate it more as well. Thanks for any info.
02 SE V6 (S/C) AT
scdsolara619
Postby Dawgz » Tue Feb 19, 2008 7:34 pm
i think it says on the manual that a little bit of shavings here and there are okay, is it extensive?
Postby scdsolara619 » Tue Feb 19, 2008 7:48 pm
Dawgz wrote:i think it says on the manual that a little bit of shavings here and there are okay, is it extensive?
I've never seen any before with the old setup - this is all new and it seems very extensive.
02 SE V6 (S/C) AT
scdsolara619
Postby CamryOnBronze » Tue Feb 19, 2008 8:28 pm
i had a similar thing when i first installed my setup, but im not sure how much you are experiencing.
Postby Eye8Pussies » Wed Feb 20, 2008 12:19 am
keep an eye on it, but I wouldn't worry too much about it either- that belt can take quite a beating
my setup leaves a lot of rubber everywhere as well, but I know that it's partially due to the fact that my setup doesn't perfectly align in my gen3
the only thing that's really happened is that I've had to replace my belt and both my grooved idler pulleys after having the blower on my car (with new belt and pullies) after less than 2 years.
Return to Forced Induction
