SolaraGuy.com • View topic - Parts needs for S/C
Parts needs for S/C
Parts needs for S/C
Postby YESCA » Thu Feb 28, 2008 11:03 am
Ok. After reading a post on here, i relized I too am missing some parts from my S/C. :( I have the idler assembly, the actuator looks just fine, but I don't think I have all the bolts for it. Can someone tell me what bolts are supposed to come with the charger, or if someone has a pic and sizes of the bolts, it will help out alot. I am a little worried about this. I'm having one hell of a time locating the EGR tube, and I will have to one made, i just don't want to pull my hair out on locating the hardware for this. ANY HELP will be greatly appericated!!!! As things look ATM, I have a $2000 paper weight. I'm just glad I didn't start installing it. ALSO, does anyone have a PDF I can print out for the install??
I'll get some pics up tonight of what I have and we can go from there... but any input before hand would be sweet! :bday:
YESCA
Postby CamryOnBronze » Thu Feb 28, 2008 11:20 am
do you still have the manual i sent you? that has a pdf parts list with all of the bolts required and sizes. Dawgz is your man for the bolts, he has a hook up and can probably get you all of them you need.
Postby 99V6solaraSE » Thu Feb 28, 2008 11:34 am
im in the same situation as you.
I just acquired all the hoses and the bolts.
I just looked on the installation manual at the list and looked on mostly ebay to find the stuff.
Some of that crap is pretty hard to find locally i do admit. But online you shouldnt have too much of a problem.
As for the egr you dont need to make a new one per se. You basically just use the stock, and since it isnt too far off and go to a shop and tell them to make it fit lol. TRD told me it can be massaged to fit.
i have the .pdf file. Just hit me up on aim whenever and ill send it to you.
99V6solaraSE
Postby YESCA » Thu Feb 28, 2008 1:39 pm
I don't have the hoses either, but I'm sure that regular Vacuum hoses will work, but I will look at the manual you sent me and start aquiring the parts. I can't wait till this thing in installed...lol!
YESCA
Postby shocar4 » Thu Feb 28, 2008 1:42 pm
someone just post the pdf of the manual for all of us!
shocar4
Postby Dawgz » Thu Feb 28, 2008 3:05 pm
heh
Postby CamryOnBronze » Thu Feb 28, 2008 4:23 pm
Postby JavaJoe_2 » Thu Feb 28, 2008 9:28 pm
The one way valve needed is the same one they use for the brake booster. Just go to a pull a part and cut one off a junked camry...cost me a buck and a half.
Got Boost?? :sweet:
JavaJoe_2
Postby 99V6solaraSE » Fri Feb 29, 2008 6:46 pm
damn i need to find me a check valve. Just went to autozone and it wasnt the right size. Im gonna goto toyota and ask if they can just give me one.
I remember going there before and they didnt really know wha ti was trying to find since i just showed them a parts list for the supercharger.
gonna try to install the supercharger this weekend. hopefully. :P
99V6solaraSE
Postby Dawgz » Fri Feb 29, 2008 6:57 pm
RJ, i got u on the TRD One way valve.
Postby YESCA » Tue Mar 04, 2008 10:36 pm
Ok. I am now a bit freaked out with the problems people are having recently with the install of their S/C. I have been wanting one of these things forever and I am trying to get everything i need for the install...it's a flippin' bitch. i was reading that install website...BTW you can't really read it when it is printed out) and i saw this
Dynamic tensioner. Now this is the one already one the car correct? or did TRD have on in the kit already? I know I should be thinking more clearly, but this pre-install has got me a bit frazzled.
YESCA
Postby Dawgz » Tue Mar 04, 2008 10:39 pm
the dynamic tensioner was included in the setup #2 which had a revised idler plate.
There is no dynamic tensioner on the car itself out the door from factory where the accessory belt is run.
Postby YESCA » Tue Mar 04, 2008 10:49 pm
So will i need to find one, or is it not necessary?
And Dawgs, do you still have you hook up on these bolts? and other goodies, if so hit me up and lets talk turkey.
YESCA
Postby Dawgz » Tue Mar 04, 2008 11:34 pm
well, which plate setup do you have?
Postby YESCA » Wed Mar 05, 2008 6:09 am
I dont think i will need it, but this is the plate I have.
YESCA
Return to Forced Induction
