SolaraGuy.com • View topic - Need Hose Diagram
Need Hose Diagram
Need Hose Diagram
Postby akora12 » Wed Mar 26, 2008 6:01 pm
Can someone provide me with just the vacuum hose diagram with no ebc? I have the PDF manual that was posted up on here, but the diagram is too small to read the labels. All I need is the one diagram, I can read everything else. I have searched all over for this. The diagram I am needing is pictured below.
Postby CamryOnBronze » Wed Mar 26, 2008 7:09 pm
I think I still have mine, Ill try to post it up before I go to bed tonight.
Postby JavaJoe_2 » Wed Mar 26, 2008 8:00 pm
I can barely read mine and I have the original install book. :o
Got Boost?? :sweet:
JavaJoe_2
Postby 99V6solaraSE » Wed Mar 26, 2008 10:15 pm
yea ive been sent different versions and all of them have been hard to read.
But you can still make it out barely.
99V6solaraSE
Postby CamryOnBronze » Thu Mar 27, 2008 8:14 am
dang I forgot last night, Ill try to get it on here this afternoon!
Postby akora12 » Thu Mar 27, 2008 9:30 am
CamryOnBronze wrote:dang I forgot last night, Ill try to get it on here this afternoon!
Thanks! Let me know if you need my e-mail.
Postby CamryOnBronze » Thu Mar 27, 2008 5:29 pm
This should be legible enough, if I can get into the computer lab and scan it this weekend Ill try that as well!
http://img169.imageshack.us/img169/5655/p1010067cz2.jpg
Postby akora12 » Thu Mar 27, 2008 6:21 pm
I actually need the smaller diagram without the ebc. I won't be running ebc, so the diagram above won't be applicable to me. If TRD had just made it the same size as this ebc hose diagram I could read it. Thanks.
Postby CamryOnBronze » Thu Mar 27, 2008 7:17 pm
Having the EBC effects the vacuum lines? I would have thought it would be the same... sorry that doesnt help any then!
Postby Dawgz » Thu Mar 27, 2008 9:48 pm
This isnt too clear but it works.
Postby Dawgz » Thu Mar 27, 2008 9:51 pm
The black things are Caps to cap those ends off when u take the hose out of that area. When u tie the Vacuume tank, look at the lines, there should be a plastic connector in the line, use that to loop the two lines and cut off the excess line or just zip tie it away.
Postby akora12 » Fri Mar 28, 2008 5:46 am
Thanks dawgz, that is exactly what I'm looking for.
Return to Forced Induction
