SolaraGuy.com • View topic - IAC Checkvalve
IAC Checkvalve
IAC Checkvalve
Postby ndeguzma » Mon Jul 07, 2008 12:47 pm
I've searched the forced induction posts and I can't seem to find anything on this.
Anyway, I am in the middle of installing my SC that I bought a year ago. I was collecting parts that were missing from the kit, mainly the alternator bolt (thanks, dawgz). Also, this kit came with an auto EGR tube and I have a 5sp, so I had to swap out the EGR cooler (what a hassle, as it took me 4 hours and busted knuckles).
I realize my kit did not come with the IAC checkvalve. Does anyone know where I can get one or something like it? Would a PCV valve work?
Thanks in advance as any advice would be appreciated.
ndeguzma
Postby Dawgz » Mon Jul 07, 2008 1:03 pm
u can get this at the toyota dealership, its just a regular check valve.
I believe u can use the one identical to ur brake booster's check valve.
Postby akora12 » Mon Jul 07, 2008 1:06 pm
PCV valve will work, but you may have to play around with the hose sizes. I've also heard of people using the brake booster valve like dawgz mentioned.
I can sympathize with your egr cooler swap hassle. I swapped mine and it was some of the most frustrating work I've done on a car yet, go figure.
Postby Eye8Pussies » Mon Jul 07, 2008 4:32 pm
what vik said about the brake booster one-way valve
OR
no valve at all seems to make no difference either....
Postby ASG14 » Mon Jul 07, 2008 4:38 pm
^ Ditto, neither of us have them (Although, they are Gen 3's.)
Or just hit the dealer. I get all my stuff at Toyota of Stamford. Order before 4pm (Try to get there before 3), and it's normally in next day.
ASG14
Postby ndeguzma » Tue Jul 08, 2008 8:31 am
Thanks all, got my checkvalve ordered.
Hopefully I can finish this weekend. I have the vacuum lines to do, put the throttle body back on, install the pulley plate & belt and replace the coolant, that made a mess after changing the EGR cooler.
ndeguzma
Postby Dawgz » Tue Jul 08, 2008 8:50 am
make sure u put some anti-sieze on that alternator bolt's threads.
GL, post pics!
Postby ASG14 » Tue Jul 08, 2008 10:14 am
Good luck! Once you do this al the 1st time, it;s a piece of cake to do again. If for some reason you need Vacuume lines, just stop by AutoZone, they sell it by the foot.
Also, as a tip, get a long one for the PCV, and run over the valve cover, rather then under the SC, as it gets crimped.
ASG14
Postby YESCA » Sun Jul 13, 2008 8:02 am
Eye8Pussies wrote:what vik said about the brake booster one-way valve
OR
I just installed my S/C and I did not install the check valve, and I am not having a problem. Hell I'm not even throwing a CEL. I have a Gen 1.
YESCA
Postby Dawgz » Sun Jul 13, 2008 8:24 am
OR
even thought u are not getting a CEL, which you wouldnt anyway, its just a check valve, its there for protection, its there to prevent anything from going back up the tube.
Postby 99V6solaraSE » Sun Jul 13, 2008 9:21 am
OR
yea i ran without one for a while cuz i couldnt find one. Nothing really happened. But like vik says, its just for saftey
99V6solaraSE
Return to Forced Induction
