SolaraGuy.com • View topic - 318 injectors, 190LPH fuel pump, GM knock sensors UN-TUNED
Postby krook » Mon Jul 14, 2008 12:48 pm
i figured i'd post this here for a second opinion from fellow S/C'd members.
i'm gonna install injectors, a fuel pump, and (finally!) put in the GM knock sensors in hopes to resolve this issue:
http://www.solaraguy.com/viewtopic.php?t=40557
i don't have time to tune it yet, and have a broken S-AFCII unit that won't do it any good. running these items un-tuned = bad idea?
krook
Postby CamryOnBronze » Mon Jul 14, 2008 1:00 pm
the car will be running extremely rich, so i wouldnt drive it that way much longer than you have to- but if you stay out of boost you should be okay.
Postby Akfahad » Mon Jul 14, 2008 1:33 pm
^^x2...hopefully you got a shop close by to tune that bad boy.
Postby krook » Mon Jul 14, 2008 6:48 pm
also forgot to mention that i have the 5.5 pulley on, but i just didn't do the fuel upgrades at the time. so technically, i've been running lean...i suppose.
i also didn't change to the smaller belt after the pulley swap, which i'm gonna do when i upgrade the injectors and pump.
krook
Postby Mr_Chunkz » Mon Jul 14, 2008 11:30 pm
mmm me thinks youll run so rich it wont be funny
even on 5.5 psi
careful not to foul your A/F sensors. I think mine are on the way out with only 190lph fuel pump and 4psi
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Dawgz » Tue Jul 15, 2008 8:27 am
Mr_Chunkz wrote:mmm me thinks youll run so rich it wont be funny
even on 5.5 psi
takes a while to foul those.
Postby Mr_Chunkz » Tue Jul 15, 2008 7:16 pm
even on 5.5 psi
APPARENTLY NOT FOR ME! :cry:
lol
well hopefully mine arent blown
- Mr_Chunkz -
The Daily
Mr_Chunkz
Return to Forced Induction
