SolaraGuy.com • View topic - Knock sensor
Knock sensor
Knock sensor
Postby cartang » Tue Aug 12, 2008 11:50 am
Blown, Any solution , is there any way to get the GM sensor , any Web to buy them? and the best place to relocate. Thanks for the answers :)
cartang
Postby ASG14 » Tue Aug 12, 2008 11:59 am
ASG14
ASG14
Postby cartang » Tue Aug 12, 2008 12:16 pm
Thanks , Its just bolt on ?
cartang
Postby Dawgz » Tue Aug 12, 2008 1:36 pm
are u boosted? if not, the ats knock sensor kit shouldnt really be used.
but if u are, use the link asg14 posted up.
Postby JvR » Tue Aug 12, 2008 2:10 pm
Cut the wire from the broken knocksensor from your computer and connect the (second) working knocksensor also on the place you cut the wire (computer side).
So you have 1 working sensor on both computer connectors.
I am drive like that for about 4 months.
If you drive with a turbo/supercharger check if your not driving to lean.
JvR
Postby 1gSE » Tue Aug 12, 2008 2:25 pm
nice price!! would you boosted guys recommend replacing the stock sensor with this before it blows.....assuming you're throwing some boost at it of course
Solara-M62 @ 5.5psi
1gSE
Postby akora12 » Tue Aug 12, 2008 2:34 pm
^^^I'd wait till it goes. Mine have been fine at 6psi. It may not stay that way, but at least I'll know what conditions produced a blown KS.
To Dawgs
Postby cartang » Tue Aug 12, 2008 2:59 pm
Yes boosted 6 psi x 7 years. never tu thanks for the answers.
cartang
Postby Akfahad » Tue Aug 12, 2008 3:12 pm
^^just rewire your ECU, that's what I had to do and been fine for a little over a year now. Search the forum, there's should be a write up on with some diagram's
Postby SolaraPete » Tue Aug 12, 2008 5:17 pm
Bank 2 just went out on me last week - It really sucks going from boosted to "limp mode"! I'll be ordering the ats kit ASAP, its way cheaper than buying oem at $130 per sensor.....
SolaraPete
Return to Forced Induction
