SolaraGuy.com • View topic - Spark plug Question
Spark plug Question
Spark plug Question
Postby JvR » Sun Oct 19, 2008 4:29 am
Hi you all,
Yesterday my car gave a CEL error. I have not be able to check the number, but i think it's a broken knock sensor.
So my s/c must be lift to replace them.
I think it a good time to replace the spakplugs.
Am i right i need the NGK BKR7EIX-11 for my Camry on 4psi?
And these wires:
http://cgi.ebay.ca/MAGNECOR-KV85-SPARK- ... .m20.l1116
(i need 3, i have coils on the front cyl. bank)
Thanks allot!
JvR
Postby ASG14 » Sun Oct 19, 2008 8:35 am
If you replace the knock sensors, also replace:
1: Coolant hose under manifold.
2: Both Manifold to head gaskets
You'll need to drain the coolant first.
Not sure on your 2 questions, just wanted to throw the other info at you.
ASG14
Postby Eye8Pussies » Sun Oct 19, 2008 9:57 am
the plugs that you are stating are fine- the 11's should be the 2-step colder plugs
as for the wires- all wires are pretty much the same as long as they aren't cheap-ass wires. oem ones will also do just fine.
Postby JvR » Sun Oct 19, 2008 2:19 pm
Thanks for the fast reply and the tips!
@Eye8Pussies
What is understand is that the 7 in BKR7EIX-11 stands for the coldness and 11 for the gap size.
The most of you use BKR6EIX-11 ...so some hotter.
http://img.photobucket.com/albums/v414/ ... lugNum.gif
-I don't no what the best option is: BKR7EIX-11 or BKR6EIX-11
JvR
Postby Eye8Pussies » Sun Oct 19, 2008 2:46 pm
oh, hmm....sorry, you're right. I use IK22's so I just did a quick preliminary search on the NGKs, I guess I didn't look hard enough
as for the temp of the plugs, the NGK site says that the BKR6EIX-11 is what the stock 1mz should use. So, if you go two steps colder, then it should be BKR7EIX-11, which would give you extra detonation prevention for boost
I hope that cleared things up
Postby JvR » Sun Oct 19, 2008 2:54 pm
Thanks again!
:wnw:
Why are easy things so difficult :wink:
JvR
Postby Jakecallun20 » Sun Oct 19, 2008 7:51 pm
Those plugs should do fine, I reccomend the Denso IK22's. I use IK20's in my N/A engine and I've always used denso products. Never had any problems.
Hope I could help. 8)
-Jake
Postby JvR » Mon Oct 20, 2008 1:46 pm
Is IK22 the exact/complete part number?
thanks?
JvR
Postby Eye8Pussies » Mon Oct 20, 2008 2:01 pm
yup...
it's the denso iridium ik22
Postby JvR » Mon Oct 20, 2008 10:19 pm
haha,
NGK needs a number like BKR7EIX-11 and Denso IK22.
How things can be make difficult :wink:
I just found this site:
http://www.densoiridium.com/find_part.php?type=auto
JvR
Return to Forced Induction
