SolaraGuy.com • View topic - turbo
turbo
turbo
Postby solara90 » Wed Nov 05, 2008 3:59 pm
well, i can across this. http://cgi.ebay.com/ebaymotors/Parts-Ac ... 06.c0.m245
my question is this a good kit, has anyone ever put a turbo on a 2.4?
if them questions check out what are things i should repalce or upgrade befroe putting a turbo on. My car has about 91,000 miles
solara90
Postby Biggi_e » Wed Nov 05, 2008 4:01 pm
go im guessing u have the gen2 4cylinder. only person to this date that turbo'd a gen2 was tacti
Postby Biggi_e » Wed Nov 05, 2008 4:03 pm
Postby (K) » Wed Nov 05, 2008 4:08 pm
You can ask Richard (i20solara02i) about the specifics. I'm sure a new fuel pump would be on the list of upgrades as you're going to be needing more fuel (and air) now that you'll be running with more power.
A new set of grippy tires and good brakes would also be a good idea as well haha. I would also assume a clutch that has more bite as well depending on how much power you're looking at.
(K)
Postby 1gSE » Wed Nov 05, 2008 6:03 pm
i like how the auction is for the manifold but they show the whole kit. BTW i wouldn't trust ebay kits, you can probably get away with a part or 2...but an entire kit, i wouldn't risk it. I'd go with a more reputable manufacturer, or do the research and piece it together myself......which is exactly what i'm doing :)
Solara-M62 @ 5.5psi
1gSE
Postby solara90 » Wed Nov 05, 2008 8:08 pm
thanks for the help, im going to do some research. I plan on doing some type of forced induction spring time when i can ride my motorcycle
02 solara 2az
solara90
Postby i20solara02i » Wed Nov 05, 2008 10:31 pm
what year solara do you have?
im currently redoing my turbo kit and waiting for the new manifold. my turbo i have on the car will be for sale soon. i actually haven't upgrade my fuel pump. only injectors.
i20solara02i
Postby solara90 » Fri Nov 07, 2008 9:38 am
mines the 02
02 solara 2az
solara90
Postby Ruski » Fri Nov 07, 2008 10:54 am
Then your looking at the wrong kit thats for 05-07
Postby Driver2g » Fri May 15, 2009 6:45 am
any luck with your install? I was thinking about doing the same thing
02 Solara 2az-fe TURBO!!!
trd lower springs
short shifter
rear brake conversion
TRD muffler
Driver2g
Return to Forced Induction
Users browsing this forum: No registered users and 2 guests
