SolaraGuy.com • View topic - ERG Problem??
ERG Problem??
ERG Problem??
Postby YESCA » Mon Nov 10, 2008 10:04 am
Ok, so I have just had my CEL light come one and I put my scanner in and read the codes. one was for insuffucent EGR flow, and the 2nd was for too much EGR flow. The only thing I can think that would cause this is a sticking EGR valve. I was going to go buy another and swap it out, along with cleaning the EGR tube and other parts.
Has anyone had this problem before?
YESCA
Postby ASG14 » Mon Nov 10, 2008 10:48 am
Yup, it;s normal. Usually 1 code or the other, but I;ve seen both. A COMMON issue people don;t think of is the sensor on the top goes bad, so it does not correctly read the valve position. Vik had excessive flow CEL, and we just changed the sensor on the top, and all was good. :)
I'd first take the Valve off and see if the valve is sticking manually. If it seems to be fine, chances are, it;s the sensor.
ASG14
Postby 1gSE » Mon Nov 10, 2008 12:45 pm
i got an egr excessive flow back in march (dam it ran like sh*t too!) I just unplugged the battery for a lil bit then it went back to normal, haven't had a cel since
Solara-M62 @ 5.5psi
1gSE
Postby YESCA » Mon Nov 10, 2008 1:17 pm
1gSE wrote:i got an egr excessive flow back in march (dam it ran like sh*t too!) I just unplugged the battery for a lil bit then it went back to normal, haven't had a cel since
I tried that, but it has not changed. the CEL went off and it came back on in a matter of a few miles. I even reset it with my scan tool.
YESCA
Postby Dawgz » Mon Nov 10, 2008 1:23 pm
ASG14 wrote:Yup, it;s normal. Usually 1 code or the other, but I;ve seen both. A COMMON issue people don;t think of is the sensor on the top goes bad, so it does not correctly read the valve position. Vik had excessive flow CEL, and we just changed the sensor on the top, and all was good. :)
Hell yaaaaaa :drinking:
Postby Midias » Mon Nov 10, 2008 2:21 pm
Clean the egr with throttle body clean if no go then get a new sensor.
Return to Forced Induction
Users browsing this forum: No registered users and 108 guests
