SolaraGuy.com • View topic - Blown ATS/GM knock sensor on my 3mz hybrid
Postby trd4life » Mon Dec 01, 2008 4:55 pm
Well my N/A 3mz/1mz blew the front bank knock sensor 5 minutes ago. Cant believe i blew the GM ones with no boost :x
Postby ASG14 » Mon Dec 01, 2008 4:58 pm
wtf? How?
ASG14
knock sensor
Postby trd4life » Mon Dec 01, 2008 5:08 pm
weird must have been a bad batch of gas or somethin? Not sure if i am gonna do the re-wire or fix it the right way lol. Bank 1 is the firewall side correct?
Postby akora12 » Mon Dec 01, 2008 5:15 pm
^Yes
Postby Eye8Pussies » Mon Dec 01, 2008 6:55 pm
damn that sucks
but who knows...maybe something DID knock, and it saved your engine at least!
Re: Blown ATS/GM knock sensor on my 3mz hybrid
Postby shidosha01 » Thu Dec 04, 2008 8:51 am
trd4life wrote:Well my N/A 3mz/1mz blew the front bank knock sensor 5 minutes ago. Cant believe i blew the GM ones with no boost :x
Well if you need another set I've got some laying around from when I was s/c'd. Let me know.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Akfahad » Thu Dec 04, 2008 9:06 am
^^wow...welcome back Riz
Postby shidosha01 » Thu Dec 04, 2008 9:30 am
Akfahad wrote:^^wow...welcome back Riz
Thanks. Your car looks pretty mean as heck! Keep up the good work.
Get at me Gabe. I've got these knock sensors for you.
shidosha01
Postby hksboost » Sat Dec 06, 2008 9:47 am
Are they re located or in the same place of the original Knock sensor?
TurboNetics T-60
471 Whp / 467 lbft @ 20 psi
hksboost
Postby ASG14 » Sat Dec 06, 2008 9:58 am
^ I talked to him yesterday and he said they were. He tapped the rev limiter so that may have done the trick.
But I guess this shows the GM sensors still work correctly for the car.....
ASG14
Postby hksboost » Sat Dec 06, 2008 10:52 am
^ yes i don't think that we will find better than the GM Knock sensor
TurboNetics T-60
hksboost
Postby Slut » Wed Jan 28, 2009 5:47 pm
First off.. How do I test a gm knock sensor? Continuity between the pin & body? I think ATS f'd me over.. I believe they gave me a bad sensor a few months back.. I keep gettin code p0325.. for sensor one.... i put both ats sensors in at the same time.. if i switch the wires at the ecu.. itll change to p0330 showin sensor 2 is bad... which one would be for 0325.. the one on the bank closer to the firewall correct? Also what GM part # or knock sensor do I replace it with if it is bad?
Slut
Postby thakidd » Sun Mar 22, 2009 2:03 pm
it must be that maine gas gabe......
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby gnegroni » Mon Mar 30, 2009 5:25 am
Just asking, what gas are you running on that engine Gabe?
gnegroni
Postby trd4life » Mon Mar 30, 2009 6:25 am
Just to clear this up, the knock code i got ended up being a spoof, the sensor was not bad and after i cleared the code it never came back.
91 octane with stock timing
Return to Forced Induction
