SolaraGuy.com • View topic - supercharger newb
supercharger newb
supercharger newb
Postby amabsolute » Wed Dec 17, 2008 2:57 pm
Hey guys, I'm going to be picking up a supercharger some time next week my question is is there a way to tell just by looking at it what kind of condition its in or if it works properly. any telltale signs i shoould be looking for ? probably not but it doesnt hurt to ask
thanks
amabsolute
Postby ASG14 » Wed Dec 17, 2008 3:33 pm
Well, the 4 main things I'd say.
1: Make sure all the metal tubes are attached.
2: Make sure the silver metal part on the top of the SC (Thottle Body side) turns freely.
3: Spin the shaft that the pulley is on, and make sure is spins without getting hung up. Listen for any off metal noise from the bearings.
4: Change the oil. 2 reasons for that. Make sure there IS oil in it, and it should be changed once in a while.
ASG14
Postby akora12 » Wed Dec 17, 2008 4:57 pm
If possible, check the oil in the nose. A lack of oil can lead to premature failure of the bearings, and a rebuild isn't cheap. Since most SCs are now getting older, be willing to deal with any maintenence issues that might arise.
Postby amabsolute » Wed Dec 17, 2008 8:35 pm
thanks for all the info guys but how many tubes are we talking about could somebody put up a pic or 2 for reference? thanks again i appreciate it.
amabsolute
Postby ASG14 » Wed Dec 17, 2008 8:52 pm
How bout this, when you get it, just post pics of YOURS and we can tell ya! :-D That will be easier.
ASG14
Postby amabsolute » Thu Dec 18, 2008 4:27 pm
well....that would kinda defeat the purpose of this thread....its pretty big bucks and i dont wanna get screwed......but thanks for your support.
amabsolute
Postby JvR » Fri Dec 19, 2008 6:28 am
Check if you get the oneway valve and egr tube with it.
Check the bearings of the pulleys....or better replace them with new ones.
Before you install the unit i would rebuild it with caremic bearings,new oil etc...
Then you are sure you have no problem for many miles.
JvR
Postby amabsolute » Tue Dec 23, 2008 8:41 am
here's a pic of the supercharger im going later todat to get a closer look but he said this part was broken...can anybody identify this part and give me a general idea of $ to replace? thanks in advance
amabsolute
Postby akora12 » Tue Dec 23, 2008 9:15 am
There are a couple of plastic rivets that hold the actuator onto the bracket so the metal arm can open and close the valve. If just one of the rivets is busted, you can jb-weld it tight—I actually did this with mine and it held up great.
If the diaphragm in the valve is torn, you'll have to replace the whole valve assembly. Check here if that's the case:
http://www.solaraguy.com/viewtopic.php? ... highlight=
Postby ASG14 » Tue Dec 23, 2008 9:33 am
It;s about $60 to replace. You need to buy a new one ($35 I think, Dawgz here on the forum can give you info where to buy it), and then you just need to have the arm on it extended , so should cost you like $30 to have someone weld it. Thats actually a really normal part to break.
What is the price of the SC?
*Edit: just saw the info on a new one is in link above, lol.
ASG14
Return to Forced Induction
