SolaraGuy.com • View topic - Knock sensor relocation
Postby cartang » Sun Dec 21, 2008 6:08 pm
I received 2 GM Knock sensors, both they have a white wire with 2 terminals look like small plugs, non instructions, where its the best place to relocate it , any specific place , Do I have to put both or just one ,my toyota tech. is going to do it this tuesday. Thanks for the answers.
Camry 99 , 5speed, SC 6 psi, Walbro 190 gph pump , Jim fuel system upgrade, Greddy cat back, Whiteline sways bars ( F,R), TRD quick shifter,TRD strut bar, Tokico struts,eiback springs, Enkei Shogun rims, 235/45/17 Brigestone LT42 :)
cartang
Postby akora12 » Sun Dec 21, 2008 7:10 pm
The ATS sensors are intended to replace the OEM sensors in the same exact locations. I wouldn't relocate the ATS sensor b/c they aren't as sensitive and may not pick up any actual knocking.
From my experience, do not cut back the harness for the sensors or you'll have problems with getting a good ground. You should be OK if you splice right behind the OEM plugs before the plastic encasing.
Return to Forced Induction
Users browsing this forum: No registered users and 108 guests
