SolaraGuy.com • View topic - Since there's all this turbo talk...
Postby 1gSE » Tue Mar 24, 2009 5:15 pm
I was gonna keep this a secret from you guys until i finished, but i wont be like that :) So....i picked up a 28x5.5x2.5 front mount intercooler, a used bosch blow off valve (i think its a stock 1.8t unit), bought jims fuel mod from killa cam. My Holset H1C snail (old school!!) should be here tomorrow...well it should have been here today but all this snow got dumped on us last night. It needs a rebuild....that kit should be here..tomorrow or thursday, i'll rebuild it saturday if it gets here in time and send off the parts to get balanced. I'll be using a 38mm tial to keep it in check. I doubt the 2jz injectors i have are gonna be enough, so i'll be looking into some rc injectors, or some 88 non turbo rx7 460cc's since i read they're supposed to work over on TN. Tuning will be handled by an AEM FIC, that i bought. It shipped today, i just need to call up AEM and get the flying lead since the guy i bought it from had a PnP harness for a scion tc. I'm also gonna pick up an extension harness ( JEGS http://www.jegs.com/i/AEM/017/30-2989/10002/-1# Midias, care to add that to the aftermarket parts list?)) so i won't have to cut into the factory wiring harness. Some VDO gauges (boost and oil pressure) are on the way. So far total spent, not including shipping, 754. Yes folks, thats turbo, intercooler, engine management and some more :P
yes i'm gonna clean it up before i put it on
it's got a rather large turbine housing, but i seen it spool on a low
compression KA24DE...it should work nicely on the 1mz 8)
FIC > emanage
More, updated pix to come when the parts get here
Solara-M62 @ 5.5psi
1gSE
Postby ASG14 » Tue Mar 24, 2009 5:24 pm
Take a close look at the hoses on the fuel mod for cracks, mainly around the fittings. If there are cracks there it needs to be replaced. I have spare hose I can sell from making the new fuel mods.
And my TRD SC needs a mate, I need a snail for it too. lol
ASG14
Postby funboy102 » Tue Mar 24, 2009 5:31 pm
This is gonna be cool! The labor is gonna be pretty intense huh?
funboy102
Postby 1gSE » Tue Mar 24, 2009 5:40 pm
ASG14 wrote:Take a close look at the hoses on the fuel mod for cracks, mainly around the fittings. If there are cracks there it needs to be replaced. I have spare hose I can sell from making the new fuel mods.
a little dry rotted, but nothing too deep. I can probably get someone at another shop to make some new lines for me, for a case of beer
Mmm...twin charged Solara sounds like fun
funboy102 wrote:This is gonna be cool! The labor is gonna be pretty intense huh?
yeah definitely. But worth it 8)
Solara-M62 @ 5.5psi
1gSE
Postby ASG14 » Tue Mar 24, 2009 5:49 pm
Can't do that, you have to use the same hose, as it is specially made for those fittings. I talked to a performance shop that works with it.
ASG14
Postby TxBmbleBee » Tue Mar 24, 2009 5:52 pm
this is gonna be badass, keep us updated!
TxBmbleBee
Postby 1gSE » Fri Mar 27, 2009 9:14 pm
rebuild kit and gauges came in today
Still waiting on the turbo :-? It's been 10 days. Emailed the seller, still waiting on response. The guy i bought the FIC from is keeping in contact, that should be here in a few days :)
Solara-M62 @ 5.5psi
1gSE
Postby 5842solara » Fri Mar 27, 2009 9:37 pm
is this for the solara? where did you get the dual pod?
5842solara
Postby 1gSE » Sat Mar 28, 2009 12:00 am
actually that pod was from the cavalier i had. It doesn't exactly fit (small gap), but with a heat gun and some persuasion it'll fit better
Solara-M62 @ 5.5psi
1gSE
Postby 1gSE » Thu Apr 02, 2009 4:42 am
8) Got it tuesday
small ain't it?
lots of wires...not fun
OVERVIEW
The F/IC gives users with OBD-II race vehicles and non-factory forced induction systems the ability to retard ignition and deliver accurate amounts of fuel without the need for outdated FMUs or “boost hiding” controllers. This system works parallel to the factory ECU preventing tuning limitations due to complex factory timing patterns. 21x17 maps with configurable load and RPM breakpoints are easily accessed with the F/IC's Windows-based tuning software. The F/IC draws power from PC USB interface for quick and easy calibration changes.
PRECISE FUEL DELIVERY
The F/IC intercepts the signal to the stock injectors, allowing the user to modify pulse-width by +/-100%. The F/IC is the only piggy-back system that can decrease injector pulse-width, allowing the user to drive larger aftermarket injectors* while still maintaining proper air / fuel ratios. This powerful system can also tap into the factory injector signal and work independently to drive up to six (6) additional injectors.
TIMING RETARD CONTROL
The F/IC has the ability to retard timing by intercepting and delaying the outputs from the cam and crank position sensors to the engine- with no adverse affect on applications equipped with variable cam timing. The F/IC can retard timing from the factory system based on engine RPM and load inputs.
SENSOR CALIBRATION & CONTROL
The F/IC can also be used to recalibrate / clamp the MAF sensor, eliminating common problems with non-boosted factory MAFs. The on-board MAP sensor allows for proper fueling in boosted conditions.
CAN-BUS SYSTEMS NOT AFFECTED
Since the F/IC works in conjunction with the factory ECU, late model-vehicles equipped with a CAN-BUS system retain functionality of climate controls, dash and other components on the network.
Solara-M62 @ 5.5psi
1gSE
Postby 1gSE » Fri Apr 03, 2009 8:51 am
YYYYEEEEEAAAAAAAAHHHHHHHHHH!!!!!!!!!!!!
in desperate need of some love.
everyone uses a soda can....figured i'd do something different :drinking:
it's a big mofo!
Real estate is getting tight....the battery's eviction notice is coming soon. Room available out back. As much as i'm gonna miss the sound of that 6 screamin at WOT....i think i'll be just fine listening to that bad boy instead
Solara-M62 @ 5.5psi
1gSE
Postby trd4life » Fri Apr 03, 2009 8:54 am
Looking good!
Postby no_escape » Fri Apr 03, 2009 9:02 am
Should be nice and quick when all done.
no_escape
Postby 99V6solaraSE » Fri Apr 03, 2009 9:46 am
damn should be nice... get'em warrior airman! hua! lol
99V6solaraSE
Postby gnegroni » Fri Apr 03, 2009 10:30 am
1gSE wrote:Image
Best picture yet!
gnegroni
Return to Forced Induction
Users browsing this forum: No registered users and 262 guests
