SolaraGuy.com • View topic - SC alive
SC alive
SC alive
Postby cartang » Wed Apr 08, 2009 5:31 pm
After 3 months driving with PO 330 , retard and slow, Echo and Prius were faster than my SC Camry. Today the mechanic reinstalled my GM sensor kit, it was a loose conector. Anyway I changed the rear Sensor ( GM knock sensor Wells SU121, $43 Pepboys) New harness $34 and it soldier it .
No more PO 330 . Car is powerful . I am really happy, thanks for the advice Akora12, Castro, Krook, dawgs ,TRD4life, Txbmblebbe, JVR etc.
The Sc belt was changed, refilled with GM oil, greased for the bearings, and they adjusted the belt to 90 pounds by tensiometer. They changed SC coupler $30 , and snouted viton seal $ 12.
I placed 4 tires bridgestone 235/45/17 Potenza RE 960.
Maybe I will add the CPE intake . they dont have in stock ( I talked with Mr Josh , CP-E .com , He asked me, if somebody is interested to manufactured more CPE intakes ? )
The OBX headers ( without Y pipe ) can be bolt on ? I already have the Greddy EVo1. Thanks all the members. :D
Camry 99 , 5 speed, V6 SC 6 psi, Jim Fuel sistem Upgrade, Walbro 190 gph, TRD quick shifter, Greddy EVO 1, TRD body kit, TRD strut tower bar,
Whiteline F,R bars Tokico struts Eichback springs, Enkei Shogun wheels.
83,000 milles Always Syntethic oil and 93 octanes. Tampa FL
cartang
Postby TxBmbleBee » Wed Apr 08, 2009 5:54 pm
yes if he has some sort of discount i will consider getting the cpe with you
congrats on getting the car running strong again! :drinking:
"i just wanna go fast..."
TxBmbleBee
Postby akora12 » Thu Apr 09, 2009 5:50 am
Congrats, I'm glad you got everything worked out. It's always nice to have a triumph over the mechanical demons of your car.
Postby CASTRO » Thu Apr 09, 2009 6:02 am
Happy to hear that all your problems are solved. At first its always annoying when gremlins arise, but so worth it when problems are fixed right and everything falls into place. Enjoy your boostin'
CASTRO
to Tx Bmblebee
Postby cartang » Thu Apr 09, 2009 8:16 am
Hi Josh from Cpe aske what generatios is your Solara
You can contact him WWW. cp-e.com
Email Joshua JAdams@cp-e.com Thanks :)
cartang
Return to Forced Induction
