SolaraGuy.com • View topic - TRD thermostat
TRD thermostat
TRD thermostat
Postby RON » Mon May 04, 2009 3:10 pm
I'm putting one in this week (SC car). Question>>>
Can this mod pull CEL? I wouldn't think so...just checking.
P0116 – Engine Coolant Temperature (ECT) circuit range/performance problem
· ECT sensor malfunction
· Cooling system problem
Thanks
RON
RON
Postby grnsolara » Mon May 04, 2009 3:19 pm
I put one in a few weeks ago, and I haven't seen any code pop up thus far.
I read forums more than I talk. /shame
grnsolara
Postby Mole » Mon May 04, 2009 4:14 pm
no codes will be set off...
imho, it's just for looks.
Postby trd4life » Mon May 04, 2009 5:15 pm
Lol def. not just for looks.
Postby alltrac92 » Wed May 06, 2009 4:51 pm
Mole wrote:imho, it's just for looks.
OP said thermostat not radiator cap.
alltrac92
Postby RON » Fri May 08, 2009 3:52 pm
UPdate...
Just installed it and drove around in HOT weather here in LA...definitely brought the temp down and KEPT it down. Prior to the mod, I noted that my gauge was VERY steady at a point on the *thermometer logo* which I noted, so I could SEE the amount of drop on the gauge. It went from *3:00* to *3:30*. I was in stop and go traffic too. It did tend to rise after a while, but when I took it back up on the fwy, it dropped back. I would say the temps are down an average of 15 degrees. My fans are at the stock settings too.
RON
Postby 5sfe » Fri May 08, 2009 4:40 pm
your car sounds just fine, just keep an eye on it for awhile
5sfe
Postby RON » Fri May 08, 2009 10:50 pm
One thing I noticed is that at a stop (after warm up), the car idles around 40 RPM lower! Any thoughts?
RON
Postby 5sfe » Sat May 09, 2009 6:54 pm
normal
5sfe
Postby lexmex » Tue May 12, 2009 7:41 am
I've used one for about 3.5 years in my RX300 and never had an issue with it, no CELs or anything else. It can sometimes take up to a week of driving for everything to work itself out, but don't read too much into any one thing.
The only thing I really found out was a slight decline in the temperature gauge, generally stayed right in the middle or lower. I also use coolant additives (like WaterWetter, though now I am using Purple Ice) and have a Tom's Radiator Cap.
lexmex
Return to Forced Induction
