SolaraGuy.com • View topic - Boost Gauge info needed
Postby RON » Sun May 10, 2009 10:01 pm
I want to install one. Would like to get a gauge that has boost reading MAX @ 20lbs (10 is ideal)...also a POD that would fit a Gen 4 Camry Pillar (prob same a Solara?). Is there a tutorial on install here? Can't find a CURRENT one..just dead links. Basically want fitting sizes for boost port and lines and how/where to run a line through the fire wall.
Thanks
RON
RON
Postby ASG14 » Sun May 10, 2009 10:23 pm
http://www.sunpro.com/product_detail.php?pid=16358
AutoZone, PepBoys, etc carries it.
ASG14
Re: Boost Gauge info needed
Postby Dawgz » Sun May 10, 2009 10:32 pm
RON wrote:I want to install one. Would like to get a gauge that has boost reading MAX @ 20lbs (10 is ideal)...also a POD that would fit a Gen 4 Camry Pillar (prob same a Solara?). Is there a tutorial on install here? Can't find a CURRENT one..just dead links. Basically want fitting sizes for boost port and lines and how/where to run a line through the fire wall.
Thanks
RON
This one is pretty dope...
http://cgi.ebay.com/ebaymotors/VZN185-T ... ccessories
goes to 15psi. & 20 vac.
Postby STYLSH » Mon May 11, 2009 1:25 am
I've bought one from them ^^^ and on that ebay listing it also said that it goes to 15psi. But when i got it, I found out that it only goes to 10psi :) which is perfect for our s/c's.
STYLSH
Postby Ilovemylara » Mon May 11, 2009 1:50 am
I used a sunpro boost gauge. (although im not s/c yet lofl). It was 29.99 at autozone, I also bought that tubing kit linked earlier, because it didnt come with enough to run through the firewall. Once everything was ran through the firewall, i hooked it directly to the throttle body using an adapter i got at a hardware store. Works great, and for now, or at least until im boosted, it helps me measure and control my fuel econmy. Plus it just looks sweet :)
Postby Mr_Chunkz » Mon May 11, 2009 8:44 am
because i will be going turbo later, i bought an autometer c2 boost gauge. It reads boost up to 30psi...
Regardless, its still quite easy to tell what im boosting cause of the indication marks.
I put it in a glow shift swivel pod, which i will have mine up for sale soon.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Mole » Mon May 11, 2009 11:02 am
HAHA...
ron- are you the dude i got into online argument with years ago about the rotor and cut springs ? (sc3 days)
if you are, good times. hahahahaa
Postby hskrsolara » Mon May 11, 2009 8:59 pm
Thanks
RON
same one i have, with super white led's in it. You'll pay a little more, but your needle will do a lot more moving than those big 20 psi gauges. :)
hskrsolara
Postby TRDSleeper » Sat Jun 27, 2009 1:15 pm
Since most of the respondents here have boost gauges, can anybody tell me how they hooked up their gauges? I recently bought one from Glowshift and they included a T adapter to tap into the vacuum lines but I want to use the actual port on top of the TRD S/C. Please let me know the thread size and brass fitting that will fit there. Thanks.
TRDSleeper
Postby trd4life » Sat Jun 27, 2009 1:37 pm
boost fitting on the s/c is 1/8"npt female
Postby Dawgz » Sat Jun 27, 2009 3:18 pm
The one in my avatar (to the left) is the actual one i have.
Return to Forced Induction
Users browsing this forum: No registered users and 114 guests
