SolaraGuy.com • View topic - HOOD SCOOP?
HOOD SCOOP?
HOOD SCOOP?
Postby RON » Fri May 29, 2009 10:36 pm
Anyone here give it a thought? Don't want it *tacky*..but for SC, it might be worth considering for cooling. I'm not a *classic* nut, so a change in style doesn't bother me. This application comes with a grill inside the scoop.
Here's an example:
http://www.mrhoodscoop.com/servlet/the-324/toyota-camry-hood%2C-toyota/Detail
RON
Postby Mr_Chunkz » Fri May 29, 2009 10:40 pm
pass on the scoop
You wanna keep the engine cool? Run a Ram Air intake that leads from the fromt bumper to the intake filter element.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Ilovemylara » Fri May 29, 2009 10:41 pm
Go for it!, although it would look better if molded and paint, it still is unique. But if you intend to use it for cooling, be prepared to chop your hood. And ppl cant call it ricer, when you've got the mods to back it up.
Postby RON » Fri May 29, 2009 10:47 pm
Ilovemylara wrote:Go for it!, although it would look better if molded and paint, it still is unique. But if you intend to use it for cooling, be prepared to chop your hood. And ppl cant call it ricer, when you've got the mods to back it up.
Yes..I would have the body shop MOLD the edges ..or blend them in. Paint match for sure. Naturally, the hood would need to be cut open. I know a body guy and could get it done fairly cheap.
Question...would RAIN pose a problem? Lot's of cars have 'em, so I don't think it would be.
RON
Postby RON » Fri May 29, 2009 10:57 pm
Found this older post here:
http://www.solaraguy.com/viewtopic.php?t=40720&highlight=hood+scoop
And this was *ONLY* modestly venting the hood. A scoop in front of the SC would probably keep things MUCH cooler when the car is moving, since it's a form of RAM air..not simply *venting*.
RON
Postby Mr_Chunkz » Fri May 29, 2009 10:59 pm
does your car have an overheating problem? It really shouldnt..
Rather than hack up your hood I may also suggest adding methanol injection. It is quite expensive ( be prepared to out at least 450 dollars ) but the benefits are boundless. The car revs much freeer from all RPM and the engine runs very very cool if you jet properly.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby QuickSEV6 » Fri May 29, 2009 11:15 pm
Not exactly my cup of tea.
Hood scoops were originally designed to feed more air directly into the carburator which was normally, directly in the center of the engine bay and center of the hood.
If you are using a supercharger, the air comes from the drivers side of the car, where it is filtered before it enters the engine.
If you put a scoop in the center of your hood, it would really have no performance adding abilities. If you put the scoop on the side, where it could really function, I think it would cosmetically hurt the car.
Postby drewcrane » Sat May 30, 2009 6:27 am
i like hood scoops ,but like others are saying it wont help much ,and it looks like its off a mustang,or something of the like,but i always say its your car do what you want :fadein:
"its a vanishing point thing you wont understand"
drewcrane
Location: 13.7 sec.s @bandimere ,5800 ft above sea level
Postby stereopaul511 » Sat May 30, 2009 6:43 am
Skip the scoop.
stereopaul511
Postby Midias » Sat May 30, 2009 8:56 am
Keep it cool like this
Postby trd4life » Sat May 30, 2009 9:01 am
I've got a small OEM WRX scoop going on my solara hood for the M90 uprgraded s/c project i am doing.
Postby Donnie » Sat May 30, 2009 9:44 am
Now we have to kill you.
Donnie
Postby panic » Sat May 30, 2009 9:58 am
Cosmetics aside, the height as shown won't do anything. The forward surface of the hood is already well designed to deflect air up over the car smoothly, and the scoop is almost entirely within either the boundary layer or surface turbulence.
Has to be at least (just a guess) 2" taller to pick up "clean" air.
That's why they put them on the front: they can be smaller.
panic
Postby onefiend » Sat May 30, 2009 10:42 am
Save your money, that's a useless mod on your Gen4 Camry.
onefiend
Postby 99V6solaraSE » Sat May 30, 2009 12:59 pm
[quote="dominoSLEV6"]Image
Gregs old one.
Greg's new one flipped around.
He doens't have the picture of it facing forward anywhere I don't think. While something that small won't provide the airflow of a cowl hood. It WILL work and it IS functional. And honestly I don't think looks half bad at all.
99V6solaraSE
Return to Forced Induction
