SolaraGuy.com • View topic - TRD4life M90 S/C
TRD4life M90 S/C
TRD4life M90 S/C
Postby trd4life » Sun Jun 28, 2009 9:30 pm
GreenSolara01
The return style fuel system will give me the ability to install an adjustable fuel pressure regulator, so i can lower and raise fuel pressure. I plan on running a fairly large set of injectors on the stock ecu with an SAFC, the only way i am going to be able to do that is by lowering the base fuel pressure so the car will idle correctly, then i can ramp the fuel pressure back up as boost kicks in.
The M90 is a much better match for the 3.0 V6 Engine, a lot of my customers want to run 10+psi and make more than 300whp and its just not possible with the small TRD charger . I am planning on discharge temps with the M90 being 75 degrees cooler than the m62 at the same boost level. With a built motor and proper cooling , 400whp should be easy with this charger :)
No the charger is not going to be sticking out the hood lol, its funny that you posted a pic of that S/C SC400 i talked to that guy on the phone before about that blower kit he made for that car!
Postby ThatVietGuy » Sun Jun 28, 2009 9:33 pm
Gee, I get the feeling this is supposed to be in another topic :drinking:
ThatVietGuy
Postby trd4life » Sun Jun 28, 2009 9:55 pm
Untouched M90 on bottom, TRD charger on top you can see how much beefier the m90 is :)
M90 Dicharge Port
Brand new TRD S/C on the left stock intake manifold on the right. The stock intake will be cut up and a portion of the lower runners will be used for the S/C manifold.
Postby Ilovemylara » Sun Jun 28, 2009 10:29 pm
GAH! i Cant wait to see that thing put together!
Postby Dawgz » Sun Jun 28, 2009 10:32 pm
Honestly, this looks very promising 8)
Just a question though, at what price do you expect these kits to be when you are done? or is it to early to estimate?
Either way, GL with the fabrication.
Postby trd4life » Sun Jun 28, 2009 10:50 pm
Still to early to tell at this point, i havent received any quotes from my fabricator.
Postby sydemoid » Mon Jun 29, 2009 5:21 am
that thing is monsterous!..... guess it may be time to save some cash
sydemoid
Postby GreenSolara01 » Mon Jun 29, 2009 1:49 pm
Good info, thanks.
I have been looking for a TRD SC alternative. I have not had much luck finding one in good condition around NC. I like the trd becuase it is easy. However this M90 looks like a monster.
How do you plan on keeping the car flat in th corners if you ditch the strut bar?
good luck w/the mod, keep it all posted.
GreenSolara01
Postby trd4life » Mon Jun 29, 2009 2:07 pm
I am working very hard to make the trd strut tower brace clear, it just may not be possible to do the mass of the m90.
One of my first kits is actually going to NC to a mr2 guy :)
Postby Dawgz » Mon Jun 29, 2009 3:14 pm
If this happens, you should go and call TRD for a job in the R&D department. :D
Postby Solarizona » Mon Jun 29, 2009 3:28 pm
Damn, the M90 is so much bigger. Can't wait to see this thing run.
Solarizona
Postby Dawgz » Mon Jun 29, 2009 6:27 pm
Solarizona wrote:Damn, the M90 is so much bigger. Can't wait to see this thing run.
Btw, the wine from an m90 is insane!
Postby trd4life » Wed Jul 01, 2009 10:53 pm
Question , would you guys be interested in retaining the stock throttle body or possibly using a larger TB from another toyota application?
Postby sydemoid » Wed Jul 01, 2009 11:11 pm
i have a bored out TB..... but hey, bigger is better, more flow= more ponies.
sydemoid
Postby TRDSleeper » Wed Jul 01, 2009 11:15 pm
I would personally want to retain the stock throttle body for simplicity sake but with such a large supercharger a bigger TB would be a better match. As long as the larger TB is easy to get then I would not mind.
TRDSleeper
Return to Forced Induction
Users browsing this forum: No registered users and 108 guests
