SolaraGuy.com • View topic - To those that have blown a Knock Sensor with the SC
Do you have the 0ne-way check valve for the throttle body?
Yes, I have one installed when it blew.
5
83%
No, I didn;t have one installed when it blew.
1
17%
Total votes : 6
Postby ASG14 » Tue Jul 14, 2009 7:00 pm
Do you have a one way valve installed?
ASG14
Postby hskrsolara » Tue Jul 14, 2009 10:20 pm
You finding a correlation here?
hskrsolara
Postby ASG14 » Tue Jul 14, 2009 10:38 pm
Trying, lol. I have a feleing it may be a leading cause in many cases. But not always the cause.
ASG14
Postby hskrsolara » Tue Jul 14, 2009 10:52 pm
I will have to go check, its definitely a possibility. Might be a good idea to post a picture pointing out the check valve location, so guys know where to look. Good heads up!
hskrsolara
Postby JvR » Wed Jul 15, 2009 3:01 am
What valve ?
The one you need to install for the s/c? (one way valve)
Driving without this valve is not possible because the rpm is going up in idle.
I have a other valve then the one you get with the s/c.
JvR
Postby akora12 » Wed Jul 15, 2009 4:50 am
^I've driven with my valve removed with no problems.
However, my valve was installed when I blew my sensor.
Postby Gibson99 » Wed Jul 29, 2009 7:12 am
which one do you mean - the one near the fuel rails or the one to the brake booster? i blew the sensors on my 95, and i did have both of these 1-ways installed, as per TRD instructions. but i was being stupid in the rain and hit the limiter in 2nd (auto) and i'm pretty sure that's what blew em.
what theory are you working on?
Gibson99
Return to Forced Induction
