SolaraGuy.com • View topic - Supercharger alternator pivot bolt
Postby alltrac92 » Thu Aug 27, 2009 4:20 pm
closed
alltrac92
Postby akora12 » Thu Aug 27, 2009 4:46 pm
Nice find. I'd be in, but I bought a spare from Dawgz a while back when he got the rest of the TRD supply.
Postby 99V6solaraSE » Thu Aug 27, 2009 6:30 pm
if this goes thru.. ill get one..
99V6solaraSE
Postby alltrac92 » Thu Aug 27, 2009 7:12 pm
closed
alltrac92
Postby RON » Thu Aug 27, 2009 8:24 pm
PM sent. Get a HARDENDED bolt that can't strip inside the counter sunk head.
RON
Postby Dawgz » Thu Aug 27, 2009 8:34 pm
RON wrote:PM sent. Get a HARDENDED bolt that can't strip inside the counter sunk head.
Make sure u guys use some anti-seize on the threads as well as BEHIND the countersunk tip, thats the main cause of the bolts locking up.
Postby alltrac92 » Thu Aug 27, 2009 9:16 pm
^good tip on the anti-seize. Also you need to use a 6mm metric allen socket. Using a standard allen will not seat properly in the bottom of the bolt head.
alltrac92
Postby ndeguzma » Fri Aug 28, 2009 8:19 am
I'm in.....
ndeguzma
Postby ndeguzma » Fri Aug 28, 2009 8:20 am
I'm in for a couple.
ndeguzma
Postby alltrac92 » Mon Aug 31, 2009 3:18 pm
closed
alltrac92
Postby Dawgz » Mon Aug 31, 2009 4:25 pm
I wasnt going to do this again because last time i got aggrevated.
But since there is still so much interest in them, I will try to source them...give me a week or so...and ill post some updates.
Postby Dawgz » Mon Aug 31, 2009 4:34 pm
This will be my new project for the next week, to source everything in the pic below....even the mushroom bushing.
Re: Supercharger alternator pivot bolt
Postby RON » Mon Aug 31, 2009 5:45 pm
alltrac92 wrote:I found a source for the 10mm x 1.25 x 100mm countersunk alternator pivot bolt. The thread length is 32mm and the rest is plain shank. I have to buy a minimum of 20 and they are $8 per bolt. Is there anyone here who wants to buy a spare bolt?
For those shopping around..it's called a *Shoulder Bolt*..the shoulder is the smooth portion and it looks to be around 68mm or so.
RON
Postby Dawgz » Mon Aug 31, 2009 6:26 pm
A shoulder bolt is the one we use to hold the Supercharger pulley plate to the water pump housing area, that mount. The actual name for the bolts in question is countersunk.
Postby alltrac92 » Mon Aug 31, 2009 6:52 pm
closed
alltrac92
Return to Forced Induction
