SolaraGuy.com • View topic - looking into buying a supercharger for a 1MZFE v6 engine
Postby stringbean » Thu Aug 27, 2009 11:18 pm
As said im entering the market for a supercharger for my 1994 toyota camry V6 1MZFE engine, preferably one capable of 5 to 7 psi. Not sure on price cause im just looking around but if a reasonable offer comes up id probably seriously consider it, but i am trying to pay my way through college so it may be hard....
stringbean
Re: looking into buying a supercharger for a 1MZFE v6 engine
Postby SleeperSolara » Thu Aug 27, 2009 11:30 pm
stringbean wrote:As said im entering the market for a supercharger for my 1994 toyota camry V6 1MZFE engine, preferably one capable of 5 to 7 psi. Not sure on price cause im just looking around but if a reasonable offer comes up id probably seriously consider it, but i am trying to pay my way through college so it may be hard....
All of the TRD S/C can push 7 psi, the most i've seen is 11 psi.
It's all about the pulley size.
Postby Dawgz » Thu Aug 27, 2009 11:44 pm
ur looking at roughly 2500 ~ 3000 just for the supercharger alone.
Postby Mr_Chunkz » Thu Aug 27, 2009 11:51 pm
technically i think the max is 13 psi
ask gabe, hes pulled 13 psi on it before :D
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Jakecallun20 » Fri Aug 28, 2009 12:23 am
The S/Cer's are becoming harder and harder to find with low miles so good luck, and yeah...looking anywhere from 2000-3000 dollars for a good one. By the way, not entirely sure...but be careful with the 1994 1MZ as they are the picky ones, the ECU is very difficult to please and much different than the later gens. I'm sure king will chime in sooner or later so correct me if I'm wrong.
-Jake
Postby ASG14 » Fri Aug 28, 2009 5:16 am
^ Just need to relocate the knock sensor and modify the A/C idle up vacuum switch. :)
ASG14
Postby SleeperSolara » Fri Aug 28, 2009 8:22 am
:o
That's crazy. :o
Didn't know that!!!!
Postby 99BlackSandv6 » Fri Aug 28, 2009 8:53 am
Yeah, I thought Gabe hit 13. On the Red Knight wasn't it?
Postby trd4life » Fri Aug 28, 2009 9:12 am
The 2" pulley on my old old solara hit 13psi but after i ported it the lower intake and s/c it went back down to 10psi which is what the pulley was rated at.
Postby Mr_Chunkz » Fri Aug 28, 2009 11:47 am
trd4life wrote:The 2" pulley on my old old solara hit 13psi but after i ported it the lower intake and s/c it went back down to 10psi which is what the pulley was rated at.
so on my unported lower intake and sc it should read 13?! :o
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby stringbean » Fri Aug 28, 2009 2:19 pm
Thanks for all the replys, but I'm also looking into a build your own ecu, for like 700 it sounds good, my cousin who's big into cars and computers and software development did one for his older Buick! It halls ass and burns rubber, he said if I was to buy it he'd map it for me, do you think a custom ecu would work good with the supercharger? And the rest of the car?
stringbean
Postby ASG14 » Fri Aug 28, 2009 2:44 pm
So your looking for 300+whp?
ASG14
Postby Midias » Fri Aug 28, 2009 3:36 pm
stringbean wrote:Thanks for all the replys, but I'm also looking into a build your own ecu, for like 700 it sounds good, my cousin who's big into cars and computers and software development did one for his older Buick! It halls ass and burns rubber, he said if I was to buy it he'd map it for me, do you think a custom ecu would work good with the supercharger? And the rest of the car?
Hell yes go for it.
Postby trd4life » Fri Aug 28, 2009 4:00 pm
I think the unported lower manifold was causing a restriction since it wasnt gasket matched to my orted heads, after the porting the car felt more powerful but boost was read lower.
Postby Mr_Chunkz » Fri Aug 28, 2009 9:47 pm
ASG14 wrote:So your looking for 300+whp?
imo if this is the case, waiting for gabe's m90 setup would be a wiser choice for him.. wouldnt you say?
Or... TURBO
8)
But... turbo = big $$$$
- Mr_Chunkz -
The Daily
Mr_Chunkz
Return to Forced Induction
Users browsing this forum: No registered users and 68 guests
