SolaraGuy.com • View topic - High flow cat, resonator, or straight through pipe
Postby Pogs » Thu Sep 03, 2009 8:31 am
I found a buddy to make my custom downpipe from the turbo to the catback. I know when dealing with a turbo you want as little restriction as possible. Should I get a high flow cat (bad restriction), replace it with a resonator (less restriction), or have a straight through pipe (no restriction).
I know this will make my exhaust louder, and honestly I dont want that at all, but I want to make the turbo happy. Any comments are welcome.
fyi - The cat back already has one resonator, and I really dont want to remove it...
Thanks,
Doug
Search and Win
Pogs
Postby CamryOnBronze » Thu Sep 03, 2009 1:54 pm
I don't know about a 5sfTe, but my 5sfe camry has ripp headers, high flow cat, 2.25 inch piping, no resonators, and a magnaflow muffler and it sounds like crap. :lo: I would probably toss some resonators on there to get rid of as much of the rasp as possible.
Postby Midias » Thu Sep 03, 2009 2:34 pm
A straight through perforated resonator should be very little restriction and help a lot with the rasp.
Postby 1gSE » Thu Sep 03, 2009 3:34 pm
the turbo itself will do a good job of muffling the exhaust. Just stick a high flow cat in with the cat back and call it a day. Unless you're going for big hp numbers, no need to bother with making yourself a target for the police
Solara-M62 @ 5.5psi
1gSE
Postby SpeedySolara » Thu Sep 03, 2009 4:55 pm
Midias wrote:A straight through perforated resonator should be very little restriction and help a lot with the rasp.
Do all resonators come perforated like that. I'm hoping to FINALLY do my exhaust this weekend and will be adding a resonator on each of the dual pipes. I hate noise so if this is a specific resonator plesse let me know what its called and where I could get it. Thank you.
SpeedySolara
Postby Midias » Thu Sep 03, 2009 5:02 pm
^ no some are louvered. I think thrush sells a mild steel at advance auto parts that is perforated. That is a stainless silverline and I got it on ebay for about 60 bucks. Here are mine with my custom exhaust materials
Postby akora12 » Thu Sep 03, 2009 5:06 pm
SpeedySolara wrote:Do all resonators come perforated like that.
No, but all high-flow resonators should have a straight through design. Stock resonators come filled with various elements to help baffle the noise.
IMO, resonators aren't used enough in custom exhaust setups. Very few actually restrict a sufficient amount of hp, and they are vital in creating a good exhaust tone. As damon experienced, my honda sounded like absolute crap without a minimum of 2 good resonators.
Postby Midias » Thu Sep 03, 2009 5:13 pm
Here are the 2 side by side
Postby SpeedySolara » Thu Sep 03, 2009 5:14 pm
Midias wrote:^ no some are louvered. I think thrush sells a mild steel at advance auto parts that is perforated. That is a stainless silverline and I got it on ebay for about 60 bucks. Here are mine with my custom exhaust materials
Ok im going to see if i can get those at advance auto parts. Made by thrush, right?
SpeedySolara
Postby Midias » Thu Sep 03, 2009 5:18 pm
This was the one I got from there, Buy some paint stripper and some acetone to wipe it down and repaint it with high temp stuff because the factory paint will not hold up.
Postby GreenSolara01 » Thu Sep 03, 2009 9:05 pm
Was that full of glass pack before you cut it?
I was thinking about useing one if I ever do cust exhaust.
GreenSolara01
Postby Midias » Fri Sep 04, 2009 4:04 am
^ it was a full glass pack but I cut it to make custom baffles for a motorcycle.
If you have time i would suggest investing in a stainless or alumnized glass pack for longevity.
Postby GreenSolara01 » Fri Sep 04, 2009 5:14 pm
good call.
GreenSolara01
Return to Forced Induction
Users browsing this forum: No registered users and 116 guests
