SolaraGuy.com • View topic - Wideband bung placement?
Postby 20SoLaRa02 » Fri Sep 18, 2009 9:44 am
Hey all,
i'm working on getting my lm-2 installed on my car. does anybody know where to weld the bung on the 1mz? pictures would be great if you have them too.
also does anybody know how to wire this thing up? its been a while since i installed my safc so i don't really remember the position/colors of the wires.
Thanks,
Michael
20SoLaRa02
Postby 1gSE » Fri Sep 18, 2009 9:55 am
after both banks merge, in the Y- pipe, before the flex pipe. Mount it between the 9 and 3 o'clock positions. I tried googling an instruction manual and this is what i came up with. I'm guessing it should be the same since it was off the lm2 page
http://www.innovatemotorsports.com/supp ... Manual.pdf
Solara-M62 @ 5.5psi
1gSE
Postby Pogs » Fri Sep 18, 2009 10:37 am
im not sure but I think he has a 2az
Search and Win
Pogs
Postby Akfahad » Fri Sep 18, 2009 10:49 am
1gSE wrote:after both banks merge, in the Y- pipe, before the flex pipe. Mount it between the 9 and 3 o'clock positions. I tried googling an instruction manual and this is what i came up with. I'm guessing it should be the same since it was off the lm2 page
x2...don't have anything in there now, currently use it as a good source for my A/F ratio reading when I tune.
Postby 20SoLaRa02 » Fri Sep 18, 2009 1:29 pm
thanks guys, before the flex pipe is exactly what i was looking for. does it matter how far from the flex pipe i am?
Thanks,
Michael
20SoLaRa02
Postby GzNutz » Fri Sep 18, 2009 1:59 pm
Shouldn't matter.
Re: Wideband bung placement?
Postby RON » Fri Sep 18, 2009 4:15 pm
20SoLaRa02 wrote:Hey all,
Thanks,
Michael
Bung: Install the oxygen sensor’s bung upstream from the catalytic converter
(a bung and plug is included in the LM-1 kit). Any decent muffler or
exhaust shop can do this for you. The wide-band oxygen sensor is then
installed into the bung to take a reading. (Insert the plug into the bung
when not in use). The bung must be installed in the exhaust pipe at
the side or on top, NOT on the bottom of the exhaust pipe. Best
position is between 10:00 and 2:00 position.
Funny, I just posted a reply on this very issue. I had my Dyno at Church Automotive and they take the A/F from the TAIL pipe. They state that the #s read about .7 to 1.0 HIGHER A/F than before the cat. I had a bung installed on my first Dyno right where they say in the quote above....said I was RICH and leaned it out at the top end. Church said I was now VERY LEAN 14+ and richened big time. Church was right...the Torque went up 11 Ft Lbs and 6 HP with A/F down to as low as 12.5 before ending at 13.0.
RON
Postby 20SoLaRa02 » Fri Sep 18, 2009 4:28 pm
sorry i got a little confused there on what you said there. basically are u confirming the location stated in the quote by innovate or is the results from churches with the a/f sensor in the tail pipe better?
Thanks[/quote]
20SoLaRa02
Postby RON » Fri Sep 18, 2009 5:50 pm
20SoLaRa02 wrote:sorry i got a little confused there on what you said there. basically are u confirming the location stated in the quote by innovate or is the results from churches with the a/f sensor in the tail pipe better?
Thanks
[/quote]
Sorry for any confusion...the quote is the standard procedure for using a Bung Port. Church Automotive used a tail pipe sensor only. My point was that the second method shows *higher* (leaner) readings than the standard procedure. For me at least, Church's method seemed to work out well. I never could understand how the first results (using bung port wide band) could have shown a *rich* condition (A/F in the loww 11's)...telling them to LEAN OUT my car :-?. Anyway, I'm sure you'll be fine with the standard method.
RON
Postby Eye8Pussies » Fri Sep 18, 2009 6:07 pm
if you have a collector on your down-pipe (i.e. y-pipe), you are supposed to put it at least 6-8 inched after the collector so that you get a proper reading from both runner pipes combined
as for the position of the bung on the pipe angle-wise, that is only to prevent moisture from collecting on the sensor
and in regards to the tailpipe readings being leaner (higher) than from a proper bung reading, that is because the cat leans out the readings by collecting fuel for emissions purposes
Postby 20SoLaRa02 » Fri Sep 18, 2009 6:32 pm
thanks guys i appreciate the clear up. with that being said would the best location for the bung be before the flex pipe? that would cause the bung to be right where the exhaust flow from the front and rear headers combine, which is not 6-8" from the disturbance.
also i am running the jpp headers/y-pipe. should i put the bung after the flex pipe?
Thanks again,
Michael
20SoLaRa02
Postby GzNutz » Fri Sep 18, 2009 6:49 pm
I've got mine after the flex, before the cat. You just want it to be before the cat.
Postby 99V6solaraSE » Fri Sep 18, 2009 8:50 pm
how would this work in my case since i have the xerd headers?
99V6solaraSE
Postby 20SoLaRa02 » Sat Sep 19, 2009 7:56 am
thanks for all the help guys. i think i'm going to go about 6-8" after the flex pipe since that would be the last flow disturbance. that way i can hopefully get a even consistant reading.
99V6solaraSE - u got pictures of the xerd headers. i believe u would want to put it in a similar place as me. if i remember correctly u may not have a flex pipe, so jus go 6-8" down from where the front and rear banks join but before the cat if u have one. that's just my opinion
Thanks,
Michael
20SoLaRa02
Postby Eye8Pussies » Sat Sep 19, 2009 9:37 am
^ that should do- as said, just before the cat is the most important part
as for the xerd headers...if I remember, the runners basically merge right before the cat right?
if that is the case, for a true reading, you may be better off having a different wideband reading each runner independently
Return to Forced Induction
