SolaraGuy.com • View topic - Innovate lm-2 wiring help
Postby 20SoLaRa02 » Fri Sep 18, 2009 4:34 pm
hello,
before i get started i just want to confirm a few things. i believe all i need to hook up as far as wiring goes is the RPM signal and TPS wires. Then i would need to ground the two wires that correspond to those signals. what is the best way to ground these two wires?
also, i've been searching and haven't found a simple answer in layman's terms on how to log boost. i know we have a boost port which we can hook a boost guage. but from what i understand is i need some sort of 0-5v signal for the boost to read on the lm-2. can someone give me an example of what i would need to make this connection work.
Thanks,
Michael
20SoLaRa02
Postby 20SoLaRa02 » Tue Sep 22, 2009 2:36 pm
bump?
20SoLaRa02
Postby JamesT » Tue Sep 22, 2009 2:39 pm
Give me a second and I'll look it up for you...
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby JamesT » Tue Sep 22, 2009 2:44 pm
TPS will be be solid blue wire going into the top most connector on the ECU (pin number 23)
RPM will be a black wire with an orange stripe coming from the connector second from the bottom on the ECU (pin number 27).
If either of these don't work, let me know.
BespokeAutoInterior
JamesT
Postby JamesT » Tue Sep 22, 2009 2:48 pm
Oh, I forgot, ground will be a brown wire in the same connector as the TPS (pin 18 ).
BespokeAutoInterior
JamesT
Return to Forced Induction
Users browsing this forum: No registered users and 265 guests
